rkas3882 randy kassed (84 posts) Registered: 05/30/2010 09:14AM Main British Car: 1973 mgb gt rover 3.5 |
fuel connection rover efi
Hey guys, the rover 3.9 efi system has an odd thread on fuel fitting for the fuel line, what have you guys done to connect the fuel line? is there some type of threaded nipple i can get so i can just use some push on fuel line?
Randy |
en ian jenkins Mississauga Ont canada (67 posts) Registered: 12/27/2010 11:06AM Main British Car: 77 tr7 |
Re: fuel connection rover efi
I'm not sure of the thread but i cut the nut off and use high pressure EFI rated hose.
The tube under the nut is larger od than the rest of the tube(thats why the nut won't slide off) |
avbates Tony Bates San Jose California (25 posts) Registered: 03/22/2008 12:16PM Main British Car: 74 MGB roadster 4.2 litre Rover |
From receollection I believe the thread is something like 12 mm x 1 mm. I searched high and low looking for a solution with ho success, everything seemed to 1.5 mm. Ending up like Ian and carefully cut off the nut, leaving the nipple intact and used a normal clamp
Regards Tony Bates |
