roverman Art Gertz Winchester, CA. (2288 posts) Registered: 04/24/2009 11:02AM Main British Car: 74' Jensen Healy, 79 Huff. GT 1, 74 MGB Lotus 907,2L |
IRS axles, 1/2 shafts and 300M
I'm not sure we've discussed metalurgy on these ? Boxter 1/2 shafts are approx. 2.5" too long, each,( 10" more track width than stock Jensen Healey). These units are 28 spline x 1.200",(30.5mm), same as 930 Porsche. Reduced diameter beyond the spline/boot attachment area, so shortening is not an option. First choice in aftermarket is "Sway Away" brand, stronger than oem and less than 1/2 cost of 300M custom axels. Local axle maker uses 300M exclusively,(mostly the off-road market). This is considered "the" material of choice, when torsion strength is paramount. Anyone use this material ? Cheers, roverman.
Edited 3 time(s). Last edit at 04/12/2012 08:09PM by roverman. |
rficalora Rob Ficalora Cypress, TX (1725 posts) Registered: 10/24/2007 02:46PM Main British Car: '76 MGB w/CB front, Sebring rear, early metal dash Ford 302 |
Re: IRS axles, 1/2 shafts and 300M
talk to Frank @ 'The Drive Shaft Shop' in Salsbury NC. They do 930 style. Not sure what material.
