MV8 Steve Johnson Atlanta, GA (6 posts) Registered: 04/30/2012 06:46PM Main British Car: 1977 Spitfire 2.8L v6 and T5 |
Companion flange interchange
I have a 1977 Spitfire without a driveshaft (or engine, or transmission, etc). I've been looking at mg and triumph flanges on ebay. What applications use the correct companion flange for my application? I can see it has ujoint axles and I expect it to have a 3.89:1 ratio.
I searched without success. |
Re: Companion flange interchange
Rearend is original to the 1977 Spitfire. I assumed the differential end of overdrive and nonoverdrive transmissions is the same. I don't know what transmission it came with. Is that on the vin plate? The dash is also gone, so no overdrive switch.
I just need the companion flange and rear weld joke inorder to make a hybrid driveshaft to connect my chevy s10 T5. I may need to press and weld a ring to the spit weld yoke to step the tubing diameter up to about 2-1/2", or the smallest tubing weld yoke that will accept the s10 T5 slip yoke's u joint or maybe use a hybrid joint with two different size bearing caps and spider widths. I found one for $30 on Ebay, so I guess that is about as cheap as they get. Thanks |
