rkas3882 randy kassed (84 posts) Registered: 05/30/2010 09:14AM Main British Car: 1973 mgb gt rover 3.5 |
buick 215 pistons
Hi guys, found that I had no compression in a few cylinders which was causing my running problems, anyway after pulling things apart I found that someone had bored the engine out but put standard size pistons in! I need a source for buick hi compression pistons at a good price. Any suggestions are appreciated, thanks
Randy |
Re: buick 215 pistons, what bore ?
Randy, Let's start with bored to ?. Is current bore "munched" as result of wrong pistons/rings ? Silvolite/ Buick and rover 3.5 pistons, still available,(dished). Good Luck, roverman.
