mabie1978
Michelle Pierce
Elyria, OH
(111 posts)
08/25/2008 07:47PM
1978 MGB 3.5 Rover V8
T5 Transmission question
Posted by: mabie1978
Date: May 31, 2012 06:00PM
Hello all, got a question for you. I currently have a T5 from a v8 Camaro installed in the car but it has issues that need addressed at some point. Several syncros need to be replaced so it will probably be a total rebuild. I have a friend that has a T5 from a v6 camaro that is in good shape and he said I could have it if I wanted. How would that affect the drive train? Is a v6 one a bad fit with the v8 engine? I have the 3.5L Rover installed with the stage 3 cam from Crower.
I plan to the do the rebuild on the installed transmission and I do not figure I will be very fast so thought maybe a swap could be done. I am guessing that I would have to have the end of the driveshaft swapped as I know there are two different spline patterns, I can't remember if it varies according to the year or the engine size for the T5. Thought I would throw it out there and see what the thoughts were. Thanks!!!
Sorry to have missed the meet but Texas was just too far, since it wasn't over a weekend. Michelle
(2465 posts)
Re: T5 Transmission question
Date: May 31, 2012 08:30PM
Michelle, If you have the stock rear gears first will be really low. You could probably start out in second(or shift quickly to) and get by until you rebuild the other one. EBay has inexpensive T5 rebuild kits and manuals. Hanlon has a rebuild video: [www.hanlonmotorsports.com]
Edited 2 time(s). Last edit at 05/31/2012 08:51PM by mgb260.
Date: May 31, 2012 10:59PM
Sounds like you're making progress, Michelle. As Jim eluded to... what rear axle ratio are you running? Stock MGB (3.909:1) or something with longer legs? Makes a big difference. Dan Masters' handy Excel calculator might help you with the decisions: [www.britishv8.org]
mabie1978
Michelle Pierce
Elyria, OH
(111 posts)
08/25/2008 07:47PM
Date: June 01, 2012 06:20PM
The rear end is still stock as it wasn't necessary to change it with the set up I have in. I can actually start out in second with the gear ratio I have with the exisiting transmission, 4th gear seems to be the favored gear for cruising around town in.
