Oil breather/Valve cover baffling
Date: June 01, 2012 10:42AM
I'm getting oil dripping from my breather. There's no baffling in my valve covers -- probably means my PCV is also sucking some oil. What's a good solution (besides changing the valve covers; I like the look of the ones I have)?
Rockers are [at least currently] stud mounted but stamped vs. rollers - don't know how much room between them & the holes but will look when I get home this evening.
(2465 posts)
Re: Oil breather/Valve cover baffling
Date: June 01, 2012 12:58PM
Stainless steel kitchen scratch pad in breather. You have to buy a new PCV with built in baffle or replace with breather with tube for inline PCV.
Date: June 01, 2012 06:05PM
Thanks Jim -- but, what in the world is a kitchen scratch pad? You're mistaking me for someone who knows his way around a kitchen ;)
(2465 posts)
Date: June 01, 2012 08:10PM
Rob, The Stainless steel Scouring pad is in the kitchen section of Walmart and other stores. Looks like steel wool but 1000 times coarser. I also buy Scotchbite sanding pads there, much cheaper than auto parts stores. If you put the scouring pad up into the breather cap it works as a baffle. The older cars used similar material in the breather.
Edited 1 time(s). Last edit at 06/02/2012 03:41AM by mgb260.
(2465 posts)
Date: June 01, 2012 10:42PM
Rob, A picture is worth a thousand words! Stuff this in your breather cap:
Date: June 02, 2012 12:17AM
Cool. Thanks.
flitner
John Fenner
Miami Fl
(168 posts)
03/11/2010 10:58AM
1972 MGB 350 CHEVY
Posted by: flitner
Date: June 02, 2012 11:00AM
The PCV will only pull while under good vacuum, then the breather exhausts the crankcase pressure when into the throttle, that is why they route the breather to the air cleaner base to pull the blowby in there, I doubt there would be enough volume to get oil all the way to the air cleaner base.
thegreatscott
eric scott
(5 posts)
06/12/2012 11:53PM
Posted by: thegreatscott
Date: June 20, 2012 11:18PM
i suggest that you go to auto parts shop and get your parts changed or let them examine it and seek for their good advice
