Neutral safety switch and fuse rating
Hellow all.
I have started my rover fuel injection conversion, 2 issues have pop-up. 1st-, how to deal with the neutral safety switch, the ECU only wants 5 volt input , if i just ground the wire i will be sending 12 volts to the ECU i worry i would fry the ECU. 2nd .- fuel pump requires a fuse, i do not have the wiring diagram for the whole R.R. so i do not know the rating. My set up is MGB with 3.9 Lt Rover engine and stock Rover fuel injection, Rover 5 speed trans. I know many of you have gone down this road before me, and aquired the knowlege. Would you guys mind sharing this info with a novice?. Thank you all. Romney. |
lars49 Larry Barnes Colorado Springs (177 posts) Registered: 06/11/2009 02:12PM Main British Car: 1980 MGB GM LA1 3400 V6 |
Re: Neutral safety switch and fuse rating
Romney,
The fuse is there to protect the wire not the pump. Typically fuses are rated at 80% of the current capacity of the wire. For the safety switch you need a voltage divider. Is the switch connecting to ground and 12 volts? I don't understand your circuit if you are grounding the switch how are you getting 12 volts to the ECU? |
