Re: Laser Cut Header Flanges for Buick/Rover Aluminum V8s
Quote: I feel another song coming on.... I'll be real surprised if there is any issues between the Rover, Buick 215, & likely the Buick 300. I do know that Mike Moor reused his 215 block hugger headers on his 300. The Olds, well, that one is a bit of its own animal. Gary, I have an old 3 row Rover head that you are welcome to borrow. I have some late model Rover heads that I was planning to swap sometime this winter, so you might can also borrow a '63 215 head at some point. Better yet, Curtis can send you one of his old Buick heads since he has already swapped them out & I'll send you a Rover head. You can just return them in Omaha. Some head comparisons: [www.roversd1.nl] |
Gary, I think a bigger problem might be scope creep. These flanges fit Buick 215 and Rover. Now you're getting advice about Buick 300, Olds, TA, and even reworked Ford 1-5/8" headers - plus a few opinions about aesthetic issues. With all due respect to everyone, IMHO, you should sell a few sets and listen carefully to feedback from actual customers.
Since you have the pattern that makes real good sense. Digital files are not that hard to change. You might even consider a connector strap delete version with a dotted line type cut at the flanges for easy removal by the builder which theoretically should please just about everyone.
Beau Dirt Beau Dirt Minneapolis, MN (35 posts) Registered: 05/02/2012 03:23AM Main British Car: 1973 Morris Mini, 1930 ford Model T, 1926 Model T 1 liter Suzuki and Four 215's |
Headers By Ed here locally sells the 215 flanges already, but they are $150, and over $300 with the starter pipes.
The Olds and Buick are different. Dang. EDIT- The Buick flanges are a bit cheaper for plain- $146 $315 as shown below. I'd see these look better than Ed's, at a MUCH better value. Using the webbing during the build of the headers would sure make it easier to maintain a flat plain. Cut em out when you're done if you don't like them. For $50 it's a steal! If they will physically bolt up to the Olds heads (without the webbing) I still want two sets. Edited 4 time(s). Last edit at 11/29/2012 08:01PM by Beau Dirt. |
Quote: Eliminating the connecting straps/webbing opens up the probability of developing stress cracks and failure of the primary pipe to flange joint - early BOP/Rover block huggers did not have the flange connectors and had lousy life until the webbing was added. |
A good point, but slip joints at the collector are another way to eliminate the issue.
ex-tyke- Thanks. I was wondering about that.
Not such a problem with full length headers but I'm probably the only MGB owner running those. I can see it being a problem with the shorties.
Man, that last shot are some sorry looking flanges. The ones they sold me 25 years ago looked much better. Odd. I paid less for them too, probably something like $60-80 with the stubs. But you know, if you have a bench vise, angle grinder, and acetylene torch it is very easy to flare the tubes out to match the flanges. I did that with schedule 40 pipe when I built my turbo headers for the 215. Just make a tapered plug and heat-n-beat to fit. Simple. Jim |
Jim I think the part cut line would be ideal but I am trying to abosrb everthing people are writing. It's not about me so I am trying to abosrb what eveyone is sayng.
Gary, Your flanges look much better than "ED's". I plan on making my own for the Caddy 4.9 but using 1 5/8" round stub instead of port shape. What are the length and width of the ports in yours? Could be another option.
Gary, Thanks. Looks like a 1.625 OD round port would work fine. Flange would have to be wider. I think that is what Roverman had in mind. My port size is .875 x1.25. I will use 1.5 ID /1.625 OD stubs so 1.625 ID tubes will slip over.
Edited 3 time(s). Last edit at 11/30/2012 08:11PM by mgb260. |
Clan, I would gladly test fit a template, to a TA head. It is likely that only non-ported TA heads would use a 1 5/8" primary pipe. Ported ones would require a mimimum of 1 3/4" od. This is known as "scope creep". Cheers, roverman.
Takes a lot of power to justify those 1 3/4" primaries, Art. What is your target, 500hp? My Camaro was putting very close to 400 RWHP. Primaries were 1 5/8. Mostly street driven, though.
[www.stockcarracing.com] |
Carl and clan, It would only be a WAG., at this point. Mike at TA and TRS claim 600 hp./all motor, but No dyno sheets ! I might become a believer, when I see one ?? My TA motor will need to max power at 7,500 +. In "Vizards" example, sbc was using a dual plane, no 5/7 swap and is street bound. Onward, roverman.
Edited 1 time(s). Last edit at 12/01/2012 06:23PM by roverman. |
Wow. That much power & RPM I guess you can make good use of the bigger primaries.
So I'm guessing for that you would need to level out the line across the top a bit so the port could be raised?
I'm honestly not trying for scope creep here. Big primaries could/should be in their own category, including perhaps aluminum port adpters, like some race motors use. TA heads "might" benefit from an upswept primary, say 5 deg., which works well on Stage II V6 heads. Onward, roverman.
I reveived my set the other day. I'm super excited.
They'll go on to the Olds 215 heads. My flanges where maybe a bit too exact. I'll need just a bit of work with the rat tail to get them to fit over the studs. It looks like my flanges have a bit different profile. I'll report back with what I find once I get them on. As mentioned, they won't clear the bottom row of bolts, or my dipstick (I think the dipstick is in a different spot on the Buicks???). But on my application pulling the headers off won't be tough. :) Thanks again! |
