hirot Ian Hart Ashbourne UK (88 posts) Registered: 06/01/2011 05:15AM Main British Car: 1971 MGB GT (conversion) Rover 3947 R380 gearbox |
LT77 speedometer drive gear
Hi, has any one swapped the speedo drive gear. I am replacing a white gear for the black 8 tooth gear.
Problem is when I split the rear casing the gear dropped out and I don't know which way round to put the new one back in. The teeth are tappered one side and therefore I assume lead the driven gear in. Any help would be appreciated. Regards Ian |
