Goto Page: Previous12
Current Page: 2 of 2
MGB-FV8
Jacques Mathieu
Alexandria, VA
(299 posts)
09/11/2009 08:55PM
Re: Rear Axle Musings
Posted by: MGB-FV8
Date: January 07, 2013 02:51PM
After reading this article, I think that I would stick with the Ford 9" for extreme performance. Good reading that explains a lot.....
[www.truehi9.com]
Date: January 08, 2013 11:41AM
Jaques and clan, strength is largely a function of ring gear diameter, as Jim B. states,(as long as companion pieces are also adequate). Number of teeth, in contact is a function of of pinion to ring tooth count. Higher numerically, will have "less" tooth contact, as pinion gear gets smaller, with fewer teeth,(higer psi loading of fewer teeth in contact). Second problem is distortion under extreme shock load. The teeth are very hard and do not tolerate much deflection, before they crack and then break. The 8"/9" ford designs are stronger per pound, because of "pinion drop" is greater, this means higher tangient angles of tooth contact. This means stronger, but more drag,(approximately 5 hp. between a 9" ford and a 10 bolt gm). Onward, roverman.
nobogez07
Doug Brown
Webster, South Dakota
(58 posts)
12/11/2012 05:38PM
1971 Mk II MGB coupe 1992 302 Ford H.O. EFI
Posted by: nobogez07
Date: January 08, 2013 05:28PM
the 8.8 is tough, cheap, and easy to install with today's kits!
It can certainly handle the 250 to 350 HP engines that go into B's. More HP than that and it's a waste of time and money unless of course you're a straight liner in which case a completely new axle is in order!!
Date: January 08, 2013 06:43PM
Have you guys lost your minds? Seriously, what sort of monster motors do you envision installing that you need that kind of heft in the rear axle?
Re: Rear Axle Musings, never too late to 8.8
Date: January 09, 2013 11:53AM
Easy Jim- buddy, as we have previously learned, "some" consider the rear end/t-axle, a good source of fiber and ballast/lol. If a 8" is good then, math included, would not a 8.8 be 10% better ? Cheers, roverman.
danmas
Dan Masters
Alcoa, Tennessee
(578 posts)
10/28/2007 12:11AM
1974 MGBGT Ford 302
Posted by: danmas
Date: January 09, 2013 02:38PM
What about a 9.3" Pontiac/Oldsmobile rear end? It's featured in the current issue of Street Rodder.
Date: January 09, 2013 08:20PM
Thare ye go ! Whots in my 56' f-100. Long live the 9.3. Installed it in 1969 ? roverman.
Date: January 10, 2013 01:49PM
A reasonably prepared 8" axle is overkill for any car that ever wore an MG badge.
Since you guys are talking about axles for truck projects, I think this thread belongs better in the Drivetrain section...
Robert J
Robert Janca
Oakland, CA
(53 posts)
10/21/2011 06:31PM
1975 MGB Ford 331 Stroker
Posted by: Robert J
Date: February 10, 2013 12:58PM
I picked up a Dana 44 axle yesterday. I'm going with Bill G.'s 4-link kit. Seems to be the most rear end and suspension one can get for a reasonable price.
4Tigers
Chris Scheck
(1 posts)
05/17/2012 01:23AM
Posted by: 4Tigers
Date: February 10, 2013 09:38PM
Going with T-Bird IRS on the Super Tigers Keeping an all Ford Theme
FYI have two frames for my 57 Safari one original with 9.3 Pontiac and a second frame with a Jag irs and Mustang front susension
Lots of good info Jim - Makes this a good forum
I'll start a build thread on the Tigers when the Frames are done
Later, Chris
