JHerscher
John Herscher
SWFL USA
(13 posts)
05/28/2011 08:50PM
1974 TVR M, 70 MGB
Buick 215 water pump drive
Posted by: JHerscher
Date: February 11, 2013 06:45PM
Car: TVR M
Engiine Buick 215
Transmission LT77
Has anyone used a gilmer drive for the water pump on this engine? If so, what did you use?
Clearance between the chassis and the nose of the standard (short) pump pulley are creating the question. I believe a gilmer drive will allow me to avoid having to modify the chassis crossmember between the shock pickups.
The pulley shown below will fit the shaft and allow clearance for the belt to slip between the chasis crossmember and the pulley, but if someone has already done this, then I'm not afraid to borrow someone else's success and it will save me from trying to figure out a crank drive pulley & belt.
Thanks
John
