8" Ford will take how much ?
Date: February 18, 2013 11:37AM
Stock axles, anybody got torque or hp, they're holding ? I had to trade a hood for this thing, and it's already set-up, for a Jensen Healey. I prefer 5 on 4.5" wheel pattern(options), vs the standard 4 on 4.25" bc. What limited slip, is anybody using, and why. Thanks, roverman.
socorob
Robbie
La
(173 posts)
09/17/2009 04:42PM
Re: 8" Ford will take how much ?
Posted by: socorob
Date: February 18, 2013 01:26PM
I'm using an eaton tru trac 4.10 in mine. Can't remember what it was rated for but much more than my little 6 could ever make.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: February 18, 2013 05:44PM
Maybe a phonecall/email to Currie or Moser?
flyinlow
Kevin .
Elko NV
(84 posts)
01/25/2011 04:52PM
1964 Spitfire Ford 5.0
Posted by: flyinlow
Date: February 18, 2013 06:25PM
I had a stock 8" diff out of a maverick in a pinto wagon that had a really healthy 351 windsor and I hammered on it really hard for several years, i broke allot of stuff but never hurt the 8"diff.
(6590 posts)
Date: February 18, 2013 07:00PM
Might take Currie's spec with a grain of salt. One time back in 1980 I think they told me one of their 8" axles would handle 1000 hp. Yeah,... maybe for a couple of passes.
Dan Jones
Dan Jones
St. Louis, Missouri
(311 posts)
07/21/2008 03:32PM
Posted by: Dan Jones
Date: February 19, 2013 11:27AM
Some of the drage racers report they will handle up to 400 HP if you
stud the pinion retainer and carrier caps and use premium hardware.
The guys I know use the Ford Trac-Loc on the street and Detroit Lockers on
the strip. Ford made a couple of different clutch type limited slips.
The Equa-Loc is the earlier version. Also, there were 2-pinion and 4-pinion
Trac-Locs. The 4-pinion variety are much stronger than the 2-pinion.
If you use the Trac-Loc, don't use lube with friction modifier. Instead,
get the Ford friction modifier in a bottle and only add enough so the clutch
discs don't chatter around tight turns. The Detroit Locker is expensivebut
but very strong.
You can substitue a solid pinion bearing spacer for the crush sleeve to adjust
the pinion bearing preload. Under hard use, the crush sleeves can collapse
and unload the bearing preload.
I don't know if they make a Daytona pinion bearing support for the 8" but its
highly recommended for 9". A friend kept killing his 9" in 428CJ powered Cobra
replica (11 seconds in the 1/4 mile on street tires) until he installed one.
Dan Jones
Date: February 19, 2013 11:37AM
Clan, all good info. It appears 31 spline axles are available. I suspect the iron housing is slightly stronger than the aluminum ? New 4 pinion "track-loc",for good prices on ebay. If I buy axles and a posi, might as well opt. for 31 spline ? Thank you, roverman.
Re: 8" Ford will take how much ? Update
Date: February 19, 2013 02:08PM
Currie says "no way" to 31 spline axle, in an 8" case. Stock axles are rated at 280hp and theirs is 400-450hp.Your results may vary, use caution when applying clutch and throttle ! Cheers, roverman.
(6590 posts)
Date: February 19, 2013 02:32PM
I still say you have to go by ring diameter, provided the other parts are up to snuff. (8" parts are, MGB parts are not). General rule of thumb, 8" is good for 300-400 hp, 8-1/2" is good for 500, above that go with 9", etc. Metric sizes are equivalent. So a 200mm equals 7-7/8 and is roughly equivalent to the stock R&P but may have stronger axles and spiders and matches the lower part of that 300-400 range. A 7-1/2" would be a reasonably good choice in the 250-300 hp range.
Bear in mind you can exceed these guidelines without breaking the axles and much depends on how you drive, but if you use full power at any speed, whether the tires slip or not, R&P life might be considerably less than you expect. I flat wore out a stock R&P that was in fine shape in less than 20K miles behind about a 300 hp motor. That ring gear is real close to being an 8" diameter. So if you want it to last and you like to feel the motor pull, don't go minimalist on your axle size or you might be changing them out a lot sooner than you'd like. You don't need to go overboard either, an 8.8 or 9" axle is way more than any MGB is ever likely to need, unless it is permenantly fitted with wrinklewall slicks and all that goes with them.
Date: February 19, 2013 07:09PM
I'm starting to think this 8" , with full floating axles, is better suited for my 4L., Huffaker TR8 ,than a 9". I will do several kinds of racing and will need "easy" changing of ratios-just short of a quick change. This makes the 8/9" a better choice than the TR8 diff., which has maybe (2) ratios available, and a real pain to change/set-up, in the car or bench. I suspect the 8" has, just slightly more drag, than other comparable r&p's. Onward, roverman.
(4637 posts)
Date: February 19, 2013 09:07PM
8" full floater... so are you thinking Speedway's "Mini Stock" - like Phil is using on his RV8 GT2 car?
Date: February 20, 2013 05:37PM
No QC for me, too many parts, more drag and no oem look. I would "like" bolt-on snouts, but no luck yet. Onward, roverman.
bashby
Bill Ashby
Colorado, USA
(26 posts)
12/18/2009 09:46AM
1967 Sunbeam Alpine Series V Nissan CA18DET, 1850cc's
Posted by: bashby
Date: April 01, 2013 11:52PM
I have been told that a 8" Ford was good for 400 HP., although it is torque that shreds them... I have 4.11's and an Auburn LSD in my Ford 8" (behind a turbocharged 1.8 liter) which is in my Sunbeam Alpine SV.
