Re: LS4
Will you guys indulge me by answering more newbie questions?
In this photo, if you remove the indicated bolts and the cover they evidently secure, what do you find underneath? I thought the short answer must surely be "camshaft", but I couldn't imagine why a camshaft cover needed to be so large or why it should require four (or more) bolts. Where did Chevy put the LS4's crank position sensor and trigger wheel? Edited 1 time(s). Last edit at 02/26/2013 11:25PM by Moderator. |
Re: LS4
Here's a nice and newly introduced accessory for the LS series fans; pretty nefty I must say.
[www.streetlegaltv.com] |
Re: LS4
Jim B, That is the only picture I have but the starter on the Buick 3800 V6 and the Isuzu is on driver side. That is the bellhousing I need for the 4.9 to AW4 ,also a driver side starter. You know you got me to consider the passenger side now. You can notch the bellhousing out to clear the starter nose on that side and just ignore the bulge on the other side or cut and weld where you need it.
Edited 1 time(s). Last edit at 02/27/2013 11:44AM by mgb260. |
Re: LS4
That's true. The starter could probably go on either side but for the MGB I think the passenger's side is going to be the best in most cases, even if the bell has to be cut to accommodate it. There may be a few cases where the driver's side is better but that may cause problems with the oil filter. Dan's car being a TR7 has more side clearance, therefore more room for the starter on either side so it could be done either way if the oil filter clears and there is room to change it. I do have doubts about that though. Just keeping that option open since that bellhousing has the bulge in place on that side. But really, since I do have a tig welder it isn't that much of an issue and I can move the bulge and add bosses as needed.
I do think the better approach is the way we've been going with it, because you can attach the starter with a simple bolt-on bracket. Most won't want to mess with welding. Scott, I'd sure like to see a couple of photos of that Northstar flywheel if you think that will work. Jim |
Re: LS4
Re: LS4
Greg, Does'nt the older 90's Isuzu using the 2.8 and 3.1 with same flexplate as 2.2 and 3100 with the 60 degree belhousing use the Aisan tranny? Or do they use the GM tranny? Looks like that bellhousing has the starter on the passenger side. That old picture I posted is from your classic Jeep thread. Glad to have you on board!
Edited 2 time(s). Last edit at 02/27/2013 06:39PM by mgb260. |
Re: LS4
Nope, that starter pocket is on the drivers side. The Aisin automatic with the V6 appears to be only a two year deal. Before that, the Isuzu V6 came with the GM autobox. The 2.2 always had the Aisin tranny, but the GM based V6's (2.8/3.1) had the GM tranny.
Greg |
Re: LS4
Quote: Curtis, good question, never really thought about it but here's a picture that shows. The rear crank seal fits into the cover. Quote: The crank position sensor is here toward the back of the block. The trigger wheel is, of course, toward the back of the crank. My engine is a 2006 so it should have the 24 tooth trigger wheel. The 2007 and later engines should have the 58 tooth. Regards Scott |
Re: LS4
Quote: Jim B. did you mean the starter rather than the flywheel? I hope to get to a local parts store this weekend to get some measurements of one. I am curious too. I believe there is a decent chance it could work. Regards Scott |
Re: LS4
Hi Carl, I'm upgrading. I spent the last couple of years researching stuff. I knew I wanted to go to an LS motor. Decided on the LS4 about a year and a half ago and have been planning since then. I'm quite a ways off from doing the conversion though. Just collecting the parts and getting the starter sorted out for now. I have a ton of work to do getting ready for Omaha.
Regards Scott |
Re: LS4
Carl, That is the best picture yet! The 3800 flywheel looks good except 8 holes instead of 6. You could plug and drill it or a small V6 flywheel but, I'm leaning more towards Jim B's idea of a cut down larger LS flywheel. Instead of attaching the ring gear to the flywheel just stack the cut down flywheel on top of the flexplate. If the flexplate is dished it would require a spacer between and longer bolts. You would have to drill the flywheel for the pressure plate for the small V6(S10/Camaro). Spec,Ram,Zoom and Centerforce have HD pressure plates.
Edited 1 time(s). Last edit at 02/28/2013 12:23AM by mgb260. |
Re: LS4
Carl, I wondered how long before you got to the party. :-)
flyinlow Kevin . Elko NV (84 posts) Registered: 01/25/2011 04:52PM Main British Car: 1964 Spitfire Ford 5.0 |
Re: LS4
I have three northstar starters off engines for another project.
Two are on brand new engines and one has about 5,000 miles on it. I won't be using them since the engines will be mounted to a Porsche 930 transaxle. If you need measurements or need a starter let me know. Kevin |
Re: LS4
Below is a cut and paste of a post from another forum. Anyone wondering why I get excited about LS engines, please read the short article. 451 hp and 380lb/ft from a junk 4.8 truck motor with an upgraded top end?!? Then it gets wild.
I know this is a " Old Thread" but I just read this artical and was amazed and thought I would share it with everyone. It's from a old issue of Hot Rod mag Sept 2011. The artical was called " The Big Bang Theory" where a team of guys wanted to test just how strong Ls motors really are. Anyway long story short they pulled a 4.8L truck motor out of a junk yard. The only changes they made to the short block was to increase the top ring gap from 0.015 to 0.028. They ported the stock heads and added larger intake valves (2.0in)and upgraded the springs, changed the cam to a off the shelf 228/230 comp cam with a new set of comp hydraulic roller lifters.Then changed the stock intake and upgraded to 75lb/hr injectors and a 102 mm throttle body. naturally aspirated it put down 451hp and 380 lb ft of tq all the way out to 7000rpm. I know thats not all that amazing but what they did next was, They added a pair of 76mm turbos a intercooler, and blow off valve. After a bunch of runs they increased the boost all the way up to 26.8pounds of boost and made 1,203 hp at the crank for 60 pulls with no damage to the stock internals. Just thought i would share if anyone has the chance find the sept 2011 hot rod and check it out. [www.hotrod.com] |
Re: LS4
Of course, that's with an iron block. Most Silverado trucks & ALL 4.8s are iron blocks.
Jim, I've been watching this thread & lurking on the LS forums for long time. You know I have been talkin 'bout a wider (not quite Jim Stabe wide, though) MGB with an LS engine for years & years. My dad's Miata sitting right next to his '63 B is the main reason for wanting a wider stance. I think it started with the 6" wider MGA that showed up at the 2003 British V8 Meet in Townsend, TN, You can see it here [www.britishv8.org] Not sure I'll ever widen my car by 6", but I can definitely see an LS under the hood. Calvin Grannis sure has stoked the fire! Edited 1 time(s). Last edit at 02/28/2013 05:31PM by MGBV8. |
Re: LS4
That last pic has me thinking that, at least, one normal, vertical starter bolt may be doable.
Or not. (Moderator edited post to remove watermarked photo.) Edited 2 time(s). Last edit at 03/17/2013 10:49PM by Moderator. |
LS Quick Start Guide
Lots of good info:
[www.pirate4x4.com] [www.pirate4x4.com] Edited 1 time(s). Last edit at 02/28/2013 10:05PM by MGBV8. |
