new ford efi intake
Kaase p-38 cross-ram efi. [www.mooregoodink.com]
I can't find the price on this unit, but it doesn't matter as I know I'm not gonna be able to afford it. But how cool would this look under the hood of an mgb??? Edited 1 time(s). Last edit at 02/20/2013 02:56PM by mgbreis. |
Re: new ford efi intake
Looks cool & I looked at their web site... but I still don't see any sort of throttle control. What am I missing.
The throttle shafts are vertical (with linkage hidden below), so all you can see in the photo above are bearing bosses except for a throttle position sensor atop the furthest away (#8) runner. I wouldn't be surprised if they left some of the linkage off for the sake of a prettier picture. It certainly is a pretty picture!
Looks good, too bad they ran out of funding, and had to paint the rocker covers, in Red Oxide. Wrinkle finish is just slightly more. roverman.
Jim Inglese may have one of his cross rams left. Last time I checked it was $5295.00 including the manifold, carbs, and linkage. Supposed to be ready to run out of the box.
Mooneyes has the manifold only for $595 - [www.mooneyesusa.com] You'd still need to source the carbs (not cheap) and come up with a linkage but I actually seriously considered this at one point. You may be able to bolt up the Weber look alike EFI units that are available. Sure would be sweet to see. Edited 1 time(s). Last edit at 02/25/2013 06:14AM by DC Townsend. |
So Art, des that eBay price include the RedLine computer? If it does, that's actually not that bad. $1600 worth of "carbs" and another $600 for the manifold. This is the guy I was thinking of for the throttle bodies:[www.efihardware.com]
David's mooneyeusa link says $895. They must have noticed an up-tick in the number of hits on that page so raised the price!??!!??!
Rob, Mooney's intake manifold looks quite a bit different than the top Kaase intake manifold. The Kaase I/M seems to be strictly developed for electronic fuel injection; my thoughts.
Rob, too funny. Must have seen the number wrong though, even a $895, it doesn't seem too out of line.
Agree - $600 would be better but even $895 isn't bad. Other than the EFI kits that use a regular intake and carb looking throttle body, this is the first set up for the ford that I like the look of. I'm still holding out for the prices to come down a bit. When I do switch over I want both efi and distributorless timing control.
I wonder if it would improve the under hood clearance any? Seems like it should. BTW, when I looked at something similar about 6-7 years ago, the price was $1200 from an Australian outfit that was offering them. I think the Mooney intake is a relatively recent offering.
Probably true. That's where the rear distributor on Chevy's comes in handy so the throttle body and filter can come off the front center.
Cool filter options. Something to tuck away for a future build.
