(2974 posts)
Seized T56
Date: March 05, 2013 01:25PM
Not in customs, run low on lube. Anyone rebuilt one of these ? I haven't pulled it yet. Should be a challenge, to pull apart. Thanks, roverman.
Jim Stabe
Jim Stabe
San Diego, Ca
(711 posts)
02/28/2009 10:01AM
Re: Seized T56
Posted by: Jim Stabe
Date: March 05, 2013 04:23PM
Art
I had to take mine apart to install a shifter relocation kit. It took me about a week of evenings to get the job done. PM me your email address and I'll send you a pdf copy of a manual for doing the job.
(1259 posts)
What if the Hokey Pokey really is what it's all about?
Re: Seized T56
Date: March 06, 2013 04:00AM
Just my two bits.
These tranny's use needle bearings so a "soft seize" generally is survivable as it just jams a syncro.
"Rocking it" from 1st to reverse will free it up with usually no harm done. You can pull it apart to check and freshen it up, or run it as is.
If it won't unlock then a major overhaul is in store. If this is the case and it wasn't of some phenomenal historical significance, I would look for another one.
(2974 posts)
Re: Seized T56
Date: March 06, 2013 11:04AM
Thanks Fred, I shall look up the pattern. Historical significance was former owners', bride to be, wasn't going to let him spend another penny, to fix. Symtom was,he was driving along the hiway, and it went into neutral. I suppose when it cooled somewhat, it seized. onward, roverman.
Edited 1 time(s). Last edit at 03/06/2013 08:16PM by roverman.
(2974 posts)
Re: Seized T56, and recovered
Date: March 11, 2013 11:33AM
Great tip Fred ! You saved me 2.3 tons of work. I "massaged"/no hammer, the shifter into all 7 gears, after adding 3 quarts of atf. Then I ran motor and trans together, without driveshaft. Note, 5th and 6th really makes the tailshaft vibrate, without the slip-yoke in there ! Fred, next time, lunch is on me ! Onwards, roverman.
(2974 posts)
Re: Seized T56
Date: May 10, 2016 05:22PM
Ok, What is the preferred lube ? I have Type III synthetic, auto trans lube ? Thanks, roverman.
MG four six eight
Bill Jacobson
Wa state
(295 posts)
10/23/2007 02:15AM
Re: Seized T56
Posted by: MG four six eight
Date: May 11, 2016 01:17AM
Art,
If it's from a GM vehicle, the preferred lube is Manual Transmission Fluid GM part No. 88861800.
Bill
Edited 1 time(s). Last edit at 05/11/2016 01:19AM by MG four six eight.
