NCtim
Tim Shumbera
Western North Carolina
(239 posts)
01/19/2012 04:35PM
Rover 4.0L front cover ideas
Posted by: NCtim
Date: March 23, 2013 05:58PM
Hey Gang,
I've got a 4.0 with direct fire ignition that has a front cover with the hole for a distributor blanked off. I'm going to start with a dizzy and EFI so I don't have too many issues to deal with at once. Learning the MegaSuirt EFI is going to be enough to start with and then I can move down the road from there, like Curtis is doing.
Would a Buick V6 front cover fit the 4.0 and has anyone done it?
Thanks,
Tim
Re: Rover 4.0L front cover ideas
Date: March 23, 2013 07:32PM
Tim, What about the crank driven oil pump ? Will you be using MS3, so CT ignition will be an option, when your ready ? Aftermarket V6 cover may be an option, as they have dual bolt pattern for oil pan. I believe the "interim 3.9 cover", has crank driven oil pump with distributor ? Cheers, roverman.
NCtim
Tim Shumbera
(239 posts)
01/19/2012 04:35PM
Posted by: NCtim
Date: March 23, 2013 08:07PM
Hey Art,
I'm going to look at a 3.9 tomorrow from a fellow BritishV8 member. It's got the goods you mentioned. I see MegaSquirt now makes crank wheels for direct fire ignition. Anyone ever tried one?
Cheers,
Tim
(4636 posts)
Date: March 24, 2013 12:26PM
I purchased an MS3-Pro controller and a bunch of installation parts from DIYAutoTune.com - but I didn't purchase one of their crankshaft trigger wheels because theirs come with eight slots for crankshaft bolts whereas my Buick 215 harmonic balancer to accessory pulley connection has a twelve-hole pattern. Instead, I purchased a trigger wheel from an eBay vendor in England called "Canems Engine Management Solutions". It came blank except for one small hole in the center. I don't have Rover parts to compare, but you'll want to check them to see if Rover carried over a Buick style design. Why so many holes? The pulley actually mounts on six bolts but there are six additional holes to provide clearance to rivet heads that protrude from the balancer.
(6576 posts)
Date: March 24, 2013 03:07PM
I've used trigger wheels from the 4.6L Ford Mod motor, under $20 from any Ford dealer, may be available from junkyard or repair shop for near nothing. 36-1 tooth pattern for EDIS. About 1/4" wide, steel. Has lightening holes, may have to be modified for Rover.
Date: March 24, 2013 06:17PM
With (12) holes in the dampener, (6) threaded, any (2) will always cross centerline of crank. I suspect you only need (2) for securing the wheel ? If one is nervous about this, you could counterbore them, to hold concentric. Waittaminuite, how many teeth are on the roller chain cam sprocket ? Cheers, roverman.
Edited 1 time(s). Last edit at 03/24/2013 06:19PM by roverman.
mstemp
Mike Stemp
Calgary, Canada
(224 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Posted by: mstemp
Date: March 25, 2013 01:15PM
Tim,
On a 4.6L you can use a cover from a Buick V6 but the oil pump, camshaft and pan would need to be also changed. Then you need a spacer for the crank pulley. Easy to do but....
I assume your cover also has the crank driven oil pump so you could do the same as the 4.6L. As others have mentioned, use the MS to control the crank trigered ignition may be easier than making all the changes needed to run a disy.
NCtim
Tim Shumbera
(239 posts)
01/19/2012 04:35PM
Posted by: NCtim
Date: March 25, 2013 05:29PM
"I've used trigger wheels from the 4.6L Ford Mod motor, under $20 from any Ford dealer, may be available from junkyard or repair shop for near nothing. 36-1 tooth pattern for EDIS. About 1/4" wide, steel. Has lightening holes, may have to be modified for Rover. Jim"
Hey Jim,
Have you used this on the BPR engine before? On yours?
Tim
NCtim
Tim Shumbera
(239 posts)
01/19/2012 04:35PM
Posted by: NCtim
Date: March 25, 2013 05:36PM
"I purchased an MS3-Pro controller and a bunch of installation parts from DIYAutoTune.com - but I didn't purchase one of their crankshaft trigger wheels because theirs come with eight slots for crankshaft bolts whereas my Buick 215 harmonic balancer to accessory pulley connection has a twelve-hole pattern. Instead, I purchased a trigger wheel from an eBay vendor in England called "Canems Engine Management Solutions". It came blank except for one small hole in the center. I don't have Rover parts to compare, but you'll want to check them to see if Rover carried over a Buick style design. Why so many holes? The pulley actually mounts on six bolts but there are six additional holes to provide clearance to rivet heads that protrude from the balancer."
Thanks for the info, Curtis. I'll check into this. As you know, I'm sort of following your style of build; going with EFI at first and then progressing to a direct fire. Pretty much enamored with Evan Amaya's build. He started simple and progressed to the more advanced engine management as he wrapped his head around it, kind of like I do in real life.
Tim
NCtim
Tim Shumbera
(239 posts)
01/19/2012 04:35PM
Posted by: NCtim
Date: March 25, 2013 05:38PM
Mike,
You make a good point. I'll do some more research. All I've gotten done lately.
Tim
(6576 posts)
Date: March 25, 2013 09:40PM
Used the Ford 4.6L trigger wheel on the supercharged Olds 215 (outer ring was removed from the damper and trigger wheel was welded to the back side with a few stitch welds. Also on I-H 392, same method of attachment on a full damper. Current 340 has a custom trigger milled into a fluid damper adapter.
Date: March 26, 2013 11:04AM
Jim B., what is the pn. for the Fluid dampener ? Back in the day, I would bore/hone sbc's, to fit. Thanks, Art.
(6576 posts)
Date: March 26, 2013 12:44PM
Customized Art, it was made for a 6 cylinder Jeep engine IIRC.
(4636 posts)
Date: April 01, 2013 06:41PM
To follow-up now that I have some photos...
This snapshot shows my new trigger wheel, modified to fit against a Buick 215 harmonic balancer:
See the missing tooth? That's so the computer can positively identify top-dead-center. I'll add another hole 180-degrees opposite the missing tooth to improve balance. (As if!)
Also shown: Buick 215 crank pulley, reinforcement ring, and Kia/Hyundai/Mitsubishi crankshaft position sensor (to which I mounted a Metri-Pack 150 series connector).
This snapshot shows the relationship between pulley, trigger wheel, and harmonic balancer.
As you can see, I selected the 175mm diameter trigger wheel because I wanted its teeth to stick out just slightly beyond the balancer lobes. Now I'm headed back outside to fashion a bracket for the sensor which will mount on the same two bolts as the mechanical fuel pump block-off plate (just below the alternator bracket, in foreground).
(4636 posts)
Date: April 03, 2013 01:42AM
Sensor bracket:
0.85mm clearance from VR sensor to trigger wheel teeth:
Scott68B
Scott Costanzo
Columbus, Ohio
(569 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Posted by: Scott68B
Date: April 05, 2013 03:43PM
Great craftmanship as usual Curtis!
NCtim
Tim Shumbera
(239 posts)
01/19/2012 04:35PM
Posted by: NCtim
Date: April 05, 2013 05:20PM
Man! You do some clean work. Thanks for the update.
Tim
