Make your own flywheel ?
Date: May 03, 2013 11:04AM
Well maybe! If you have access to a lathe and a drill press, a flexplate to fit the crank your using, a Fidanza steel insert with hardware, a ring gear/Pioneer, and the clutch cover you intend to use. While in the lathe, you make id/od steps to locate needed componentes concentric to C/L, they can be used a drill jigs, for needed holes. BOR's have the hardest time, finding strong and light flywheels. We can change that. Cheers, roverman.
Re: Make your own flywheel ?
Date: May 03, 2013 07:04PM
Locating the crank flange bolt holes is the hardest part, as they are not evenly spaced. The rest of it is just standard machining and as long as you're particular about the runout it's easy.
Date: May 06, 2013 11:16AM
Yes, this is why I suggested using the correct flexplate as a drill jig. Cheers, roverman.
