Goto Page: Previous12
Current Page: 2 of 2
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Re: Custom header parts
Posted by: NixVegaGT
Date: August 11, 2008 10:42AM
I emailed Jet-Hot for a quote on their coating process. Has anybody gotten a Jet-Hot coating before? It looks pretty great. They also sent a bunch of stuff in the mail for me to look at. Magazine endorsements and data. It came with a promo DVD too.
Not cheap though. $370 for my headers. What do you guys think? I think it might be worth it. They claim a big reduction in underhood temps. Like 200º less. Hmmm.
I finished the mock up of the headers on the first side. They look cool! I was able go build them so it can be removed. It just fits. Pretty bitchin. I thought the driver side would be more difficult but I forgot I have to clear the starter on the other side and it's really close to the frame rail. So I've got to have all the tubes go over instead of down along the block. That will make it a little more difficult to remove once it's built. I may have to pull the engine to remove it. We'll see.
I'll have pix tonight. It's still fun so far.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: August 11, 2008 12:36PM
Nic..
Get them done locally.. A lot of the area drag racers send there stuff here..
[www.newimagecoatings.com]
give em a call..
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Date: August 11, 2008 07:31PM
There is a guy that ports SRT-4 exhaust parts and puts a ceramic coating on them. He was saying that it made a big difference. I should ask him if he's willing to coat mine too. I do want to be certain the get coated inside as well as outside. I will definitely call New Image! Great find, Tony.
Here's some pix of my headers! Well one of them. I was able to keep them around 1" or so from eachother in length. I'm pretty keyed up about that. The extra space I made by replacing the frontrail support gusset with a different configuration really came in handy. I also had to wind the tubes around where the steering shaft goes. In my case that's right under the engine mount. Anyway here's the pix:
http://memimage.cardomain.com/member_images/5/web/2357000-2357999/2357894_280_full.jpg
http://memimage.cardomain.com/member_images/5/web/2357000-2357999/2357894_281_full.jpg
Here's some pix of them installed. Was able to pull it out with the tiniest margin. It worked out well.
http://memimage.cardomain.com/member_images/5/web/2357000-2357999/2357894_282_full.jpg
http://memimage.cardomain.com/member_images/5/web/2357000-2357999/2357894_284_full.jpg
http://memimage.cardomain.com/member_images/5/web/2357000-2357999/2357894_285_full.jpg
http://memimage.cardomain.com/member_images/5/web/2357000-2357999/2357894_283_full.jpg
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: August 11, 2008 08:13PM
Nice work!
Scott68B
Scott Costanzo
Columbus, Ohio
(569 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Posted by: Scott68B
Date: August 11, 2008 09:13PM
Nice! How long are your primaries?
(6569 posts)
Date: August 12, 2008 12:13AM
You've done some good fitting work there Nick, and at 1" you're probably closer than 95% of the headers made today. Looks like you may have a challenge on a couple of the welds, probably have to take the tube out, weld up the joints and put it back in. I found torch welding to be extremely well suited to building headers, as often I needed little or no filler rod as I went around the joints. Tig would be the same but costlier unless you already have the welder. Some builders like to weld the tube to the open side of the flange and then braze the back side for crack resistance, which is a pretty good practice. Coating the headers is an extremely good idea. Use a first class outfit who can reliably do both inside and out and will stand behind their work and will guarantee it against salt spray. You want it to last and it's worth a little extra.
BMC
Brian Mc Cullough
Forest Lake, Minnesota, USA
(384 posts)
10/30/2007 02:27AM
1980 MGB '95 3.4L 'L32' SFI V6, GM V6T5 & 3
Posted by: BMC
Date: August 12, 2008 02:13AM
I'll second what Tony says. We have had quite a few headers done there and plenty of our powder coating too. Personally, I have only good things to say.
Also, headersbyed- I still have not tried them but believe he is just exceedingly busy. You can find his contact info on this site at the very last paragraph in this article:
[www.britishv8.org]
-BMC.
Wotland
Wotland Wotland
(105 posts)
01/07/2008 08:14AM
Posted by: Wotland
Date: August 12, 2008 03:53AM
Look really great Nicolas.
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Date: August 12, 2008 10:55AM
Those are your flanges, Dimitri! Sweet.
So far the primaries are 37" long. I could take an inch or so off based on my updated cam choice. What do you guys think? I guess I'll wait to decide until I get the final specs on the cam.
I was thinking about renting time on a TIG welder but maybe I could use my brother's acetylene/O2 torch. I haven't welded with one of those since I was in high school. I remember really liking the control I got from the slower process. Jim, are you saying weld the port side of the flanges and then braze the primary side? I've never brazed before. Any special advice?
I'm definitely taking the pipes off the flanges to finish them up. Do you think I should worry about warping?
Thanks Team.
(6569 posts)
Date: August 12, 2008 01:33PM
Nick, you should alternate your welding and check often to control warping, you'll get the hang of it pretty quickly. Correct on the brazing. No real tips, just practice some and make sure everything is clean. I like bare rod and can flux for more control of the amount of flux and fill but that's just me. It's like soldering, get the base metal hot enough to melt the rod and make sure it wets properly. On your collector length, the advice I've heard was to run up the engine before coating the headers and look for a band of heat discoloration on the collector and that's where you cut it because that's the end of the standing wave. Maybe so, I took it all the way to the glass packs at that size. As far as the primaries, the longer they are the more they shift the powerband down, and that's played off against the diameter which shifts it up as diameter increases. What is your cruising rpm? I'd put that dead in the center and then adjust upwards for redline. If you tighten up on the diameter the length should decrease and vice-versa.
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Date: August 23, 2008 11:07PM
OK I finally finished mocking up both sides now. It was actually a little tougher on the right side. I had to run the tubes over the starter and that constrained things a little. I also had to turn them to clear the heater box. I ended up putting the rear tube over the third tube near the flange and down the middle to meet up with the first and second tube to run back. This caused it to be a bit longer. Here's a pic showing the end.
http://memimage.cardomain.com/member_images/5/web/2357000-2357999/2357894_291_full.jpg?001919-236
In this picture I've used the same romex wire I've been using for length. You can see that the previously mentioned tube is almost 2" longer. I'm a little bummed about that. Do you guys think this will be a problem? Also now that I have the final specs for the cam do you think I should make the overall length shorter?
http://memimage.cardomain.com/member_images/5/web/2357000-2357999/2357894_292_full.jpg?001919-236
Here's the final pix:
http://memimage.cardomain.com/member_images/5/web/2357000-2357999/2357894_287_full.jpg?001919-236
http://memimage.cardomain.com/member_images/5/web/2357000-2357999/2357894_288_full.jpg?001919-236
(6569 posts)
Date: August 24, 2008 10:34AM
It looks pretty good Nick. I wouldn't worry too much about that 2". Ed told me one time that about 90% of the headers made had worse mismatches than that so about the only thing getting closer than that buys you would be bragging rights. You've got a fine looking set of headers there.
Dan Jones
Dan Jones
St. Louis, Missouri
(311 posts)
07/21/2008 03:32PM
Posted by: Dan Jones
Date: August 25, 2008 11:01AM
Vizard has tested headers for primary length variations and says that while
180 degree headers are sensitive to a few inches of variation bank separated
4-into-1 headers are not very sensitive. Vizard also says that in his
testing average primary lengths between 24 to 36 inches yield similar results
(area under the curve) for bank separated 4-into-1 headers. At 37" inches,
you're a little on the long side. You might want to trim an inch or two.
Collector lengths between 12 and 20 inches should be goood to 8000 RPM.
In testing on small block Ford Windsors (small port and valve like the
Rover/Buick), 9 out of 10 times longer collector length, up to 25 inches,
will translate into increased performance regardless of cam or RPM.
If the choice comes down to lengthening the primary or lengthening the
collector, go with the longer collector. There will typically be a
noticeable burn pattern inside the collector which will indicate the length
the engine wants (once the engine is properly tuned for fuel and spark).
In my own testing, the mufflers were even more important than collector
length. We've lost as much as 50 HP through mufflers. Straight through
designs like the Magnaflow were nearly as good as open pipes.
Dan Jones
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Date: August 27, 2008 07:56AM
What about distance to the x-pipe? Is this part of "Collector" length on a full exhaust system?
