Re: How to pick ignition coils (for use w/ MS3 etc.)
Sounds exciting!
I bought an "MS3-Pro" ECM. It came factory-built and pre-programmed, so I got off to a quick and easy start. We should probably start a separate thread so people with more knowledge of MS2 will be sure to see. I don't know anything about getting an MS2 up and going. |
Curtis.
Looking at the single coils you got, they look very well the same as the ones that Henk-Jan-Vonk used in his V8 transformation. I have 2 Ford coil packs that feed 4 spark plugs each. Plan to mount them on each inner fender so the spark plug wires will be very short. Just need to make 2 new mounting brackets. Werner |
Hi Werner.
The Ford coil packs are a "wasted spark" setup. That means that for most v8's you are going to have plug wires going to both banks of the engine from each coil pack. Wasted spark coils need to pair up cylinders that are directly opposite in the firing order. Not really a problem but possibly not what you wanted. Positioned well, they look nice and they can be made to do anything that a coil per cyl can do. Cheers Fred |
Fred and Curtis,
I want to start with an easy and proven system as recommended in MS manuals. If the system works and is well tuned then I might change to a nicer looking setup. My MS system is the V2.2. Right now my budget doesn't allow changing to MS3-pro but might consider it for the future. My biggest problem now is to find the right software. Werner |
The megamanual will walk you right through it.
It looks daunting but break it down into small bits and it starts to make sense. Just stay away from the forums that thrive on the "techno talk" most of them have no idea of what is going on. Cheers Fred |
That looks pretty good Fred. I'm still about a year away from going to MS-III but that could be the answer.
Wow! Curtis, You never cease to amaze me! I would have never thought of a mount like that, and I've been accused of thinking outside the box.
Guess that is your surprise, huh? Looks pretty good and definitely tricky. Should go well with your custom plenum.
Jaques and Jim,
I think Edis is the way to go for simple installation. I got info from Megasquirt UK and bought several partsfrom them when I was working in the UK. What MS system do you have ? I have the older V2.2 system. Do you know if this works with Edis ? WWhat software did you download ? Jaques, I live in Lynchburg, VA. Might get together some day. The support bracket you see on this thread is the one I bought in the UK from Megasquirt.co.uk For the moment I am still working on the welding of new doorsills. The old ones were rusted out. I'll keep you informed. Werner |
Werner, I used EDIS with the 2.2, it works well, is relatively simple and very reliable. The laptop timing control is VERY good.
I will be going to MS3 sometime over the next year or so but have to build the controller first, as well as the rest of the system and as it is a complex one involving other modules linked together via CAN bus I am going to do that after the car is running on the old MS2 controller using the existing 3.57 board. The new system will use COP as well as individual EGTs. Jim |
This morning I finally ordered some spark plug wires! I had been procrastinating for way too long.
Here's an updated snapshot of my engine bay with everything bolted down tight. I ended up putting an eight-way connector on the coil pack for the eight signal leads, plus a three-way connector for the power and two ground leads. Additional close-up photos: here. (A couple tie-wraps have been left off, just in case I need to troubleshoot anything.) What are you guys working on lately? |
I love those invisible plug wires. :-) everything looks great Curtis. your work is "TOP SHELF"
Curtis, I have a question for you?
Does your ls2 truck coils have the heat sink attached to them? I'm looking for two sets of these with the heat sinks attached to them in the recycle yards (they seem to be the most powerful on the market). I was able to find a 408 R200 diff that was laying on the ground (still in the suspension) under a Nissan 300zx in the yard. Picked it up for $75, "what a steel"(normally $250 on up). I going to install it into the TR6 and play a little :-) |
Thanks Kelly! However, I pick and choose photos carefully to maintain that illusion.
------ 4.08 vs 3.45:1, eh Calvin? As if your car needed help launching! I guess with your double overdrive, you won't be sacrificing too much. Quote: Yes! This snapshot shows their back side. I hope they don't get too hot inside the box! |
Used, on eBay. I can't find a record of which seller or what I paid. I think they came off of two different cars, because one of the steel brackets was a little rusty and the other wasn't.
FYI: Go to "My Ebay" then click on "Purchase History". You can look thru recent purchases or archive (last 3 years).
