robert1839
Tristan Cook
5579 Timber Ridge Dr, Mt Vernon, Skagit, Washingto
(118 posts)
05/06/2013 11:11PM
MGB GT 1972 Buick 215
Transmission
Posted by: robert1839
Date: August 05, 2013 11:24PM
I just bought a T-5 transmission out of a 1998 mustang and I need it to mate up with my Buick 215 V8 I know the bell housing is interchangeable but witch one fits the buck 215 any one know what it’s called and where I can get one
(2463 posts)
Re: Transmission
Date: August 06, 2013 12:33AM
Tristan, The 61-63 215(&Olds,Pontiac) Buick 4 speed manual bellhousing/Chevy trans pattern. D&D make a new one also. Unfortunately the T5 you picked up is Ford trans pattern and the 94 and newer has a longer input shaft. There is a Chevy to Ford adapter and Ford spacer for the longer input shaft available from D&D. I really don't recommend stacking both adapters. It would be very expensive to go that way. Get a shorter V8 input shaft and bearing retainer from the junkyard. Then get the Chevy to Ford adapter. Speedway Motors sells the adapter also. There is someone on this board that modified the 3 speed bellhousing also. I just checked D&D and they have a .400 thicker adapter for Ford long input T5 to the much more common 61-63 Buick(&Olds,Pontiac)3 speed bellhousing. #7176-A-10-FT 3 speed to long input Ford T5. The last would be easiest and cheapest.
Edited 1 time(s). Last edit at 08/06/2013 12:51AM by mgb260.
robert1839
Tristan Cook
(118 posts)
05/06/2013 11:11PM
Re: Transmission
Date: August 06, 2013 11:41AM
Jim Nichols, would you suggest that i go back to the junk yard and and get a Transmission from a Chevy. if so is there a year i am looking for
(2463 posts)
Re: Transmission
Date: August 06, 2013 01:25PM
Tristan, Call D&D and and see if they know where a 3 speed bell housing is and how much for the adapter to the longer input Ford T5. If that's too much, you still have to find the scarcer 4 speed bellhousing for the Chevy T5. The 83-92 Chevy Camaro and Firebird is the T5 you want. The later ones are World Class and use ATF the earlier ones had 70wt gear oil. I used to mix 1 Qt ATF with 2 Qt 90wt but, Syncrhomesh is recommended for the older versions now. The V6 version has lower gears and would need a rear end with higher gears. The V8 version ratios works good with the stock MGB rear. D&D can sell you the new bellhousing with adapter but don't list the price. Here is a link to their catalog:
[www.aluminumv8.com]
Edited 3 time(s). Last edit at 08/06/2013 02:01PM by mgb260.
40indianss
don foote
(83 posts)
08/01/2013 04:35PM
Re: Transmission
Posted by: 40indianss
Date: August 07, 2013 01:09AM
actually I bought the d&d bellhousing with adapter for ford t5 it was not that expensive also you don't need to change the input shaft etc the transmission also sits level in the car with a minor bit of modification to the crossmember, the rear trans mount sits on it perfectly the shifter comes up in the middle of the tunnel opening front to rear also the next plus is the ford t5 is more readily available and less expensive than the gm the ford t5 has a variety of ratios/overdrives as the gm call d&d and ask questions they are very helpful
mstemp
Mike Stemp
Calgary, Canada
(223 posts)
11/25/2009 07:18AM
1980 MGB Rover 4.6L
Re: Transmission
Posted by: mstemp
Date: August 07, 2013 10:33AM
X2 Same as Don, Ford SVO T5 and Bellhousing with addapter plate, works perfect.
D&D have thier own bellhousing now also. Definetly it will fit a 93 and older Ford T5. The 93 and up as was already mentioned have a longer input shaft. Call Mark or Dan at D&D to find out if they can accomadate the longer input shaft.
robert1839
Tristan Cook
(118 posts)
05/06/2013 11:11PM
Re: Transmission
Date: August 07, 2013 01:52PM
ok so the ford adapter plate is that just a thick of metal right. and how much longer is the input shaft on the ford
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Re: Transmission
Posted by: ex-tyke
Date: August 07, 2013 02:45PM
The 'net indicates that '86-'93 Ford T5's have a 7.18" long input shaft and post '94 Ford V8 applications have a 7.85" length....so we have a .67" difference.
robert1839
Tristan Cook
(118 posts)
05/06/2013 11:11PM
Re: Transmission
Date: August 07, 2013 03:54PM
this one is out of a V6 dose that change anything
ex-tyke
Graham Creswick
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Re: Transmission
Posted by: ex-tyke
Date: August 07, 2013 04:53PM
No...V6 shaft length should be same as V8 (according to this website)
[www.therangerstation.com]
robert1839
Tristan Cook
(118 posts)
05/06/2013 11:11PM
Re: Transmission
Date: August 07, 2013 05:27PM
ok thanks
mgbreis
Ryan Reis
Beatrice, NE
(203 posts)
07/16/2008 11:07AM
Re: Transmission
Posted by: mgbreis
Date: August 07, 2013 11:32PM
I have a '00 v6 mustang t5 that I put the shorter input shaft in. It's been a few years but it wasn't that expensive to buy a new input. I also upgraded mine to the recommended all steel bearing retainer. I got my parts from Astro performance. The newer v6 trans supposedly has stronger gears than the older camaro t5's.
tbo
Tim Body
St Thomas Ontario
(221 posts)
01/27/2013 06:47PM
Re: Transmission
Posted by: tbo
Date: August 08, 2013 09:51PM
You can check the T5 listing of all the available ones by serial # and year. Its posted on this website. It will tell you what gear ratios you have in your tranny in case you want to know.
skiffmw
Mark Skiff
(2 posts)
04/21/2016 06:27AM
Re: Transmission
Posted by: skiffmw
Date: November 02, 2017 05:06PM
I have had a bad experience with D&D. Bell housing did not have clearance needed for ring gear. Both were supplied by D&D. Also gear reduction starter was incorrect for flywheel. Again, D&D provided all these items. Their response was to try and sell me new parts. Will never do business with them again. They are 20% higher on parts than other sources. PM me is you want more details.
Re: Transmission
Date: November 02, 2017 09:34PM
Sorry to hear that, there have been some complaints... hopefully they will begin doing a better job of dealing with them.
