Re: External Crank Trigger For GM 3400 V6
The sensor that GM uses is just a simple hall effect sensor.
Lots of other sensors can be substituted for it. The crank sensor for a LS engine comes to mind as an easily adaptable replacement. I would send your crank balancer out to your machinist friend and have him drill 24 equally spaced 0.50" holes around the circumference. Make up a bracket to aim the sensor of your choice at the balancer and you're good to go. Nice,tidy and easy. Cheers Fred |
Hmmm. Thinking back to when I first installed Megasquirt on the old International SV series engine, it originally ran on the Pertronics module so that was 4 pulses per crank revolution from the distributor (V8). Eventually I upgraded to the Ford EDIS and MS-II but it was more because I wanted IAC control than any limitation with the trigger as I recall. The question that comes to mind is, what exactly are you giving up by running off the seven pulse trigger? If per crank revolution that is twice the resolution the old IH had and it ran pretty darned good. Can your controller still advance the timing? If it can and it is just a question of how quickly the controller can react to transitions, consider that at 1000rpm it is picking up a trigger pulse 116 times a second and you my friend, cannot tell the difference between one cylinder firing and the next, only 10 milliseconds apart. You certainly will not be able to feel a slight shift in the advance of one cylinder before the next one comes around. Yet the OEM's have seen fit to go to 24, 36, 72 and higher count trigger wheels, I think I've even heard of one instance of 720 teeth. Admittedly there has to be a reason for that but I suspect it has more to do with emissions than anything else.
Fred's suggestion is probably the best one, although you can buy all sorts of trigger wheels these days. Put it in front, behind, even on the flywheel. Be mindful of the possible need for a pulse to indicate TDC, as that can affect your balance. Jim |
The GM program will run with either crank sensor signal missing.
But it reverts to batch fire instead of sequential and it uses a safer timing curve. You end up being down 15-20 hp and using more fuel. The trigger wheel for this engine doesn't have an "odd tooth" to signal tdc so no issues there. But I don't know how the timing count down is initiated so you might want to make the sensor mount adjustable to vary it's sync position. Cheers Fred |
