Francois Francois Tromp Namibia (3 posts) Registered: 08/26/2013 03:08PM Main British Car: 1952 International Pickup V12 5.3 Jaguar |
V12 radiator
Hi there
Im building Jaguar v12 5.3 into a 1952 international truck, im busy building x flow radiator but v12 have 2outlets ontop to motor, left and right Bitom its inflow from motor to radiator, but how dies radiator tanks look like inside that all water dont just pump to one bank straight up the left tank? How do i get it to flow across from left to right and up to cool? |
Re: V12 radiator
Should be one common tank. Both uppers are outlets. Bottom is inlet. Orientation of tubing determines whether downflow or crossflow.
Re: V12 radiator
Hmmm... Consider this pic:
See the red arrow? That's where there's an internal baffle straight across. That baffle makes my radiator a "dual pass" model. Your radiator is apparently more elaborate. I see a similar TIG weld in the pic you posted, so I'd assume all the water in your system flows left-to-right across the lower half of your radiator. Where does it go from there? Are there any TIG welds on the right side tank to indicate an internal baffle? I'm guessing the answer is "no"... Since the outlet at top right is smaller than the inlet, I'm guessing some of the coolant will flow right-to-left across to the other (left side) outlet. It seems to me that water flowing out of the right side outlet will be hotter than water flowing out of the left side outlet. Edited 1 time(s). Last edit at 08/26/2013 07:17PM by Moderator. |
Re: V12 radiator
can some1 please give me diagram how all the cooling pipes must conect and where all the small pipes go.....the 2 top big ones i know go into radiator and bottom also but theres 4 more, one at back mof motor and 3 infront
