Re: rods for 215
Depends on the compression height of your pistons. I like the flattops for 6" aftermarket Chevy rods. I think they have 1.25 pin height. 5.7 stock length early Chevy rods 305 piston 1.55 pin height. You want to get as close as you can to zero deck height. The Chevy rods have to be milled .050 each side of the big end and the bearing tang notches redone for the Buick bearings.
Edited 2 time(s). Last edit at 10/04/2013 11:25PM by mgb260. |
Re: rods for 215
Thanks for the info, Jim. Somewhere, I have that old HR magazine with all the rod and piston combos, but I can't put my hand on it. I started out to build the old 215 I've had for 30 years, but it may be getting out of hand. I am looking for 425 HP. I have a 3.9 Rover TPI unit, and a pair of KKK turbos, and a roller cam blank from The Wedge Shop. The Silvolite pistons might not be up to the stress. There is a set of TRW forged 305 standard pistons on Ebay, and a set of Scat H-beam rods for small journal Chevy. Probably would be a good investment, since it cost almost nothing to sleeve a block.
Re: rods for 215, got sleeves ?
Larry, "It cost almost nothing to sleeve a block", please explain ? The best sleeves are flanged, and are easily $30+/ea. Finding a shop that will properly heat the block,for exact interference fit, is difficult to find,(lack of experience). Locktite "620" is suggested. Your results may vary. Good Luck, roverman.
Re: rods for 215
Re: rods for 215
Flanged sleeves are nice, with a light slip fit, the way they are designed to be installed. However, the heat transfer to the block from the sleeve is pretty miserable. When a sleeve is pressed into the block with the proper lubricant, the heat transfer to the block is approximately ten times as good as hot dropped. This information came from Outboard Marine Corporation and research they did when they started installing sleeves after the aluminum block is cast. In this case, I have had the sleeves over 20 yrs., and I am the machinist that will install them, and you can sleeve 2 cyl. with one long sleeve cut in half.
Re: rods for 215
Larry, Please let us know your results,(perhaps a demo)? What is your target interferance fit ? Thanks, roverman.
Re: rods for 215
Forever, the sleeve manufacturers have sized the sleeves for .003 interference. The current thinking is that .003 is neither necessary or desirable. It introduces too much stress and distortion into the block. Installing a sleeve at .003 interference will distort the adjacent cylinder over .001. I prefer .0005 interference. With the sleeve sitting on a ledge at the bottom of the bore, and the head gasket fire ring bearing on the top, It's not going antwhere.
Re: rods for 215
Larry, What lubricant /adhesive do you use(Hylomar,Locktite,etc.)? Where do you get the sleeves? I always thought, how could the Rover sleeves move? Because of lack of quality control the step on the bottom is too low or sleeves too short? You might be able to pull the stock sleeves and deck the block and make sure the sleeves are reinstalled all the way to the step and then deck the sleeves. I have a previous thread on here detailing using locktite and pinning the sleeves to the block.
Re: rods for 215
Since I am new here, I just read the thread about pinning the sleeves. I don't understand how this condition can occur. The piston sits on a ledge at the bottom, and the head bears on the gasket fire ring which bears on the sleeve top. This could not allow the sleeve to "rattle up and down against the fire ring". There is a situation which occurs with "hot dropped" sleeves that might explain what is happening. The block can be heated to 400F and a room temp sleeve installed in the block. When the assembly cools, it leaves the sleeve slightly above the ledg e in the block. If the sleeve is not rapped down aga.inst the ledge before the machine work is finished, it will drop down from the block expansion and the force of the head and gasket fire ring. The lube OMC used is what I also use. It is a food-grade lubricant called Acculube LB5000.
Re: rods for 215
Thanks, Larry! I still am Interested in what you use for sleeves. I thought about using iron or steel pipe 1/8" thick for sleeve material. After all it is going to be finish honed anyway. Or reusing stock sleeves after block is decked. I think I would use at least .001 interference. I agree.002-.003 is too much and can cause distortion. There are a lot of Rover 4.0 and 4.6 crossbolted blocks going to waste. Someone should get a rover block with slipped sleeves and measure the sleeve length and distance from deck to bottom step. Should be the same so sleeves can't rattle up and down. Now if we can find someone to offset grind the 4.6 crank cheaply for strokers that would be great!
Edited 1 time(s). Last edit at 10/11/2013 12:48AM by mgb260. |
Re: rods for 215
The sleeves are no problem. They are made by many engine parts manufacturers, like Melling, Federal Mogul, Wiseco,Mahle, and others. And they are cheap. They are available by size, and come in several thicknesses, depending on the condition of the cylinder that you are sleeving. I have installed a sleeve in a sleeve on small diesel engines with catastrophic cylinder damage. (Large portion of the cylinder wall missing ) That is 2 eighth inch thick sleeves for a total of quarter inch thick cylinder wall. Most castiron engine blocks have quarter inch thick cylinder walls. It's always better to deck the block after the sleeves are installed and seated and finish bored. Oh, by the way, the sleeves come unfinished, with a .030 allowance on the inside. They are centrifugally cast and have a 200 BH hardness.
Re: rods for 215
Re: rods for 215
Carl, Thanks for the article! I know Cadillac uses an O ring on the bottom of the sleeve. About the same bore size also. As far as the taper on top, I wonder if you turned the liners around you would have a flat surface to seal against the head gasket. I would still use Hylomar or Loctite for sealer on the sleeves. Looks like 2000 and up sleeves don't move but still leak by the taper on top of sleeve because of crack behind sleeve. I thought the crack was from too long of head bolt so I would use older style bolts with washers or studs.
Re: rods for 215
Larry, For some reason the sleeves Rover used in the 3.9,4.0 and 4.6 have a angle on the top edge. The cylinder wall is thinner when they went to 94mm(3.7") bore. The headbolts are non reusable angle torque stretch type. I recommend the older headbolts with washers or studs as I think the newer ones are too long and bottom out the threads and cause the crack behind the liner. Then you have a coolant leak between the sleeve and cylinder up to the head where the sleeve doesn't seal because of the taper. The earlier than 2000 sleeves did move because they were shorter or the block bored deeper than the newer ones. I've seen them 1/4" below the deck. I'm trying to figure out a economical fix to the problem and make available 4.0 and 4.6 blocks rather than scrapping them. With the expense to do the flanged liners you could have bought another short block.
Re: rods for 215
Larry and clan, IMHO, installing a 1/8" wall flangeless sleeve, with 94+ mm bore,will render it "WET" 100% of the time! Are you prepaired for this ? "MID" sleeves are a different animal. 215's and RV8's are not designed for wet sleeves-period. (1) wet sleeve RV8, has been built with "some" success,(see rally TR7-Mikes post). It uses cast iron heads to strengthen the RV8 decks, severly weakened with wet sleeves/4.020" bores. Good Luck, I suspect you'll need it, roverman.
Re: rods for 215
Art, I agree, I plan on using stock 4.0/4.6 sleeves bored out .036 to 305 Chevy standard size. Have you pulled out a stock sleeve? Is it flat on the bottom? If so I'm thinking Caddy O ring/Hylomar on bottom, Loctite on top, sleeve flipped around and block decked.
Re: rods for 215
I am using 3 3/4" nominal bore sleeves with 3/32" wall thickness. That doesn't get into the water jacket. The sleeves installed with .0005 to .001 interference fit and pressed in against a ledge, with Acculube lubricant will not leak. There is actually no real way for leaks to occur if the machine work is properly done.
Re: rods for 215
For the record, 94mm bore, .060" wall oem RV8 blocks, crack and leak between block and sleeve, way too frequently. Larry, you'll be removing approx .059" MORE per side, than a standard 94mm RV8. Please enlighten how you will succeed, where all others have failed ? Once you remove the old sleeves, and then sonic test the remaining aluminum walls, core shift will be apparent. Block castings are approx 28 ksi.ut., with low mallebility and high willingness to crack.You might pm Tim Lanocha, about his 4.02" bore, RV8. roverman.
Edited 1 time(s). Last edit at 10/15/2013 06:54PM by roverman. |
