Re: rods for 215
Larry,I assumed would be very close, use the same Buick/Rover rod bearing. How much wider? Don't forget to add the crank clearance chamfer.
Re: rods for 215
Jim, I forgot to measure the 301 big end. Something is somewhat troubling about these rods. They really have a bad reputation with the Fiero people. (Same rod as the 2.5L Iron Duke engine.) Has anyone heard of problems with these rods in the Pontiac turbo engine?
Re: rods for 215
I didn't know they were the same as the 4 cylinder rod. I wonder if the bad rep there might be NOS or extreme turbo boost.
Re: rods for 215
Larry, There appeared to be a problem with the narrow beam on those rods, the 87 and later 2.5 ones would be better as they don't neck down. I wonder if the Turbo 301 used the thicker beam rods before they came out later for the 87 and up 2.5.
Edited 2 time(s). Last edit at 12/24/2013 04:01PM by mgb260. |
Re: rods for 215
Thanks for all the good information and help on the rods. Decided that with all the time and money involved that I would take the safest route. SBC 6" H-beam rods for $210 shipped.
