Help getting connector pins
It worked so well I'm going to try it again.
I need to find where I can get the crimp on connector pins for the later model Ford connectors for the IAC and TPS sensors. I believe these are the 4.6L parts as used on the Mustang. The IAC is the short fat body one that is supposed to be quicker and allow more airflow, and the TPS is the one with the oblong connector with two tabs on one side and one on the other. Anybody know where to get those? I'm just looking for the pins. I have the connector bodies and the old wires but I want to make a clean crimp rather than use a bunch of butt splices. Jim |
Rotus8guy John Bowman West Fork, AR (18 posts) Registered: 05/09/2013 08:10AM Main British Car: Rotus Seven Olds/Buick 292 |
Re: Help getting connector pins
That's where I got terminals and connector bodies for the Ford cam position sensor and the Chevy coil harnesses. The parts arrived promptly.
