danmas
Dan Masters
Alcoa, Tennessee
(578 posts)
10/28/2007 12:11AM
1974 MGBGT Ford 302
Horsepower is horsepower, right?
Posted by: danmas
Date: December 31, 2013 03:54PM
Reading through a DOD report on an analysis done by the Navy on captured WWII German U-Boats, I ran across a description of one of the Diesel engines used.
430 horsepower. Doesn't sound like much does it? A good Chevy 350 can easily top that.
Ah, yes, but.....that was at 375 rpm! Doing the math, that works out to be 6,020 ftlbs!!!! Holey moley! That would smoke some tires.
Horsepower and torque numbers without the rpm don't mean much, do they?
Fozwanger
jeff hedges
(10 posts)
12/20/2013 07:39AM
Re: Horsepower is horsepower, right?
Posted by: Fozwanger
Date: January 01, 2014 05:24AM
Its all about HP, torque and the break mean pressure. It's a calculation of the 2 but I can't remember what it is
mgbreis
Ryan Reis
Beatrice, NE
(203 posts)
07/16/2008 11:07AM
Posted by: mgbreis
Date: January 01, 2014 03:10PM
Anybody know if you can mate a T5 to one of these engines? ; ')
kstevusa
kelly stevenson
Southern Middle Tennessee
(985 posts)
10/25/2007 09:37AM
Posted by: kstevusa
Date: January 01, 2014 04:05PM
The TKO or Tremec will not stand that kind of torque. Maybe if we add ZZDP and silicone brake fluid, the steering can survive with just oil instead of grease.. Did we miss any controversity? Have a safe and Happy New Year.
burner1
Gary W
(212 posts)
09/24/2011 09:59AM
Posted by: burner1
Date: January 01, 2014 04:22PM
Different vehicles benift form different engines.
These are the engines my brother builds:
[www.carcraft.com]
[www.thunderv12.com]
The stock engine makes 630ft lbs at 2400 rpm which is only 275hp....stock........ People say a 302 could do that if reved to the high rpm. These are not engines for light weight sports cars.
Would you want an over reved 302 In these?
[6066gmcclub.com]
[www.ssrfanatic.com]
[files.conceptcarz.com]
[www.carbodydesign.com]
[media.motortopia.com]
[i1.ytimg.com]
BMC
Brian Mc Cullough
Forest Lake, Minnesota, USA
(383 posts)
10/30/2007 02:27AM
Posted by: BMC
Date: January 02, 2014 12:10AM
---Anybody know if you can mate a T5 to one of these engines?---
I know we have the technology and skill.
It will be an unholy mating and who knows what would become of it but if you are willing to pay...
-Here, hold my drink and watch this!
-BMC.
Edited 1 time(s). Last edit at 01/02/2014 12:10AM by BMC.
danmas
Dan Masters
Alcoa, Tennessee
(578 posts)
10/28/2007 12:11AM
1974 MGBGT Ford 302
Posted by: danmas
Date: January 02, 2014 12:29AM
A top fuel dragster engine puts out an estimated 8,000 horsepower, and is limited by the rules to 8,400 rpm. Doing the math, that equates to 5,000 ftlbs.
Holey moley!
I have a hard time wrapping my head around that.
Date: January 02, 2014 12:10PM
Burn up enough "calories", and any dyno will sweat. Nitromethane is the mother them for piston engines, as long as your afr is around 2/1 ? Cheers, roverman.
Date: January 02, 2014 05:16PM
Turning liquid directly into smoke, one combustion chamber full at a time. My oh my. Can you say "Hydrolock"?
quietone
Larry Mimbs
Tennille, Ga.
(93 posts)
07/13/2013 04:22PM
Posted by: quietone
Date: January 02, 2014 06:30PM
The Regency Hotel in Atlanta has a restaurant that the whole seating area (many tons of concrete and steel) rotates one revolution per hour. Driven by a 1HP elec motor.
(1367 posts)
Date: January 03, 2014 02:43AM
A friend of mine, Dave, runs a top fuel dragster that his son drives.
He sent me an interesting list of facts that he never really considered before.
He generally looks at every pass as a huge economic event.
As a top fuel engine runs at it's stoichiometric mixture of 1.7 to 1 (for nitro) it compresses the mixture into a near solid at full throttle.
Spark plugs run at roughly 44 amps per and are completely melted at 1/2 track. The engine diesels for the rest of the run.
The only way to shut the engine down is to cut off the fuel flow.
The cranks twist so badly during the run that the cams are generally ground to compensate for the rear cyls out of wack timing.
Some cams differ by 20 degrees from front to back.
The one spec that woke me up was the fact that the engine only made 520 or so revolutions during a run!
The other was that the exhaust exiting the headers provides around 1100 lbs of downforce.
My engines tend to last a little longer. But they come up a little shy on horse power.
cheers
Dan Jones
Dan Jones
St. Louis, Missouri
(280 posts)
07/21/2008 03:32PM
Posted by: Dan Jones
Date: January 03, 2014 01:08PM
Engine torque needs RPM to be meaningful (so you can convert it to HP).
If you know HP (specifically the average HP between shift points), you don't
need RPM to determine the acceleration. Torque is the rotary equivalent of
force and is what accelerates a car but it's the torque at the rear wheels that
accelerates the vehicle, not the torque at the crankshaft. However, horsepower
(at the crankshaft) is the measure of how much RPM can be traded for rear wheel
torque via gearing. If two engines have the same power but different torque,
they will still accelerate the same vehicle at the same rate if the gearing for
each is optimal. The engine with less torque will have to spin at a higher RPM
to do so. Gearing is the reason you accelerate harder in 1st gear than you do
in 4th or 5th (there's also an aerodynamic drag effect but that is relatively
less important for the purposes of this discussion). It's the overall gearing
provided by the the transmission, rear end, and tire diameter that is important
and this also assumes the same average power over the RPM spread between
gears, not just equal horsepower peaks.
Horsepower is the rate of producing torque, so the two qualities are functions
and directly related to each other:
HP = (TQ*2.0*PI*RPM)/33000.0
TQ = (33000.0*HP)/(2.0*PI*RPM)
where:
TQ = torque in ft-lbs
HP = power in horsepower
RPM = engine speed in revolutions per minute
PI = the mathematical constant PI (approximately 3.141592654)
Note: 33000 = conversion factor (550 ft-lbs/sec * 60 sec/min)
In general, the torque and power peaks do not occur simultaneously (i.e. they
occur at different RPMs). However, since the curves are functions of each
other, the curves will always cross at 5252 RPM when the units are torque in
ft-lb and power is in Horsepower. There's nothing magic about that number and
it will have a different value for different units. If you assume power in
Watts and torque in Newton-meters, you'll get a different cross-over RPM.
Dan Jones
