quietone
Larry Mimbs
Tennille, Ga.
(93 posts)
07/13/2013 04:22PM
main girdle for 3.5, 3.9
Posted by: quietone
Date: January 02, 2014 06:35PM
Does anyone have a pattern or template for the bottom end of the 3.5-3.9 engines?
Re: main girdle for 3.5, 3.9
Date: January 03, 2014 11:36AM
Larry, Since your going to mill it to fit, you might best dychem and scribe. How thick for material ? Accepted clearance between pan rail and girdle, is usually .005". "Sealtite" from aero industry, and silk thread should seal it up, excellent for motorcycle verticle split cases). Cheers, roverman.
(1367 posts)
Date: January 03, 2014 12:32PM
I don't have anything drafted up but you might check to see if Wotland still has that mainbearing girdle for sale still.
quietone
Larry Mimbs
Tennille, Ga.
(93 posts)
07/13/2013 04:22PM
Posted by: quietone
Date: January 03, 2014 05:32PM
I am having a dense moment. I don't understand clearance between pan rail and girdle. I had planned to attach 3/4 alum. plate to pan rails with longer studs, use long studs for the mains with studs going thru girdle and spacers between main cap and girdle. Then nuts torqued on top of the plate. Cut out only clearance for crank and rod rotation. (and oil drain if necessary) I normally use anaerobic sealers for that type of rigid joint. Maybe you have a picture of one somewhere? Thanks for the help.
