joe_padavano Joseph Padavano Northern Virginia (160 posts) Registered: 02/15/2010 03:49PM Main British Car: 1962 F-85 Deluxe wagon 215 Olds |
Re: Rover 4.6L EFI - to GEM or Thor
"What about modifying the 4BBl manifold to take the top hat directly.
Then mount your throttle body in front of the top hat. It would make for a super low profile intake." Or, just buy one of these: [www.edelbrock.com] |
GT8MX Bill Wessale Houston (43 posts) Registered: 01/10/2014 11:28AM Main British Car: 1968 Spitfire GT6 BOP 215 / Rover of some lineage |
Quote:You are not mistaken. That is correct. Quote:Thanks. If I were to extend air horns toward the front (like a header in reverse) to a plenum box i make, which is in turn, fed air from the front of the radiator, the GEMS lower manifold would look better, I think. Quote:I would like it to be in the 3500 area for street use, not race. Quote: Quote:A great idea made easier. I can't TIG, but I can braze (and epoxy). I'll look on eBay. Quote:A good rule of thumb to remember. Thanks. Quote:Yes. That's what I was picturing for mounting ontop of the throttle body and 4-BBL manifold. Quote:That's a great idea! That idea is one of those,"why hadn't I thought of that?" Thanks. |
A follow-on question that perhaps should be a new thread....
In using EFI, am I heading down a path where I will need catalytic converters? If so, that will be a problem, because it would be hard to find a space to fit them except behind the axle, which might be full of muffler. I don't believe I need catalytic coverters to pass safety inpsection because the car is a 1968 Spitfire so there are no emission limits that have to be met. Relevant questions: 1 - Can Megasquirt work with closed loop O2, but no catalytic converters? 2 - Can GEMS work with no catalytic converters? 3 - Can I put the catalytic converters behind the rear axle, with the downstream O2 sensors still mounted behind the converters? Is that too much of a lag between the O2 sensors upstream of the converters and the O2 sensors downstream which would cause Megasquirt / GEMS to "hunt"? Or would the upstream O2 sensors need to be mounted behind the rear axle just ahead of the converter? Thx, Bill |
I think you're going to want to become friendly with one of Houston's many welding shops. Nearly every idea floated in this thread involves welding. (Fuel injector bosses!) Some of these joints are going to be very visible too. IMHO, TIG is the way to go.
The welder I used to know in Greensboro was great. I couldn't afford his daytime rates, but he was happy to work on stuff after 9pm while drinking beer and talking about Harley Davidsons with his buddies. His late night rates were affordable. Megasquirt doesn't know or care about catalytic converters. A "wanted" ad in our classified section might help you find a sweetheart deal on a 2bbl Buick manifold. |
Great find on that elbow Joseph. I especially like the low profile box type.
Bill, Using the GEMS injection is going to be problematic. The ECU is coded to the body computer of the vehicle that it came from. It won't run at all without a signal from the BCM. It keeps a vehicle that breaks down every 15ft from being stolen and driven 20ft. The ECU can be unlocked and reprogrammed to work, but it's very expensive. Factory fuel injection systems are very inflexible and resistant to changes out of necessity So an aftermarket tuneable system makes more sense. Megasquirt and SDS are two injection systems that I use a lot. Both are relatively inexpensive and easy to use once you get over the initial learning curve. You can use the GEMS manifold or any other for that matter with either system. Hope that helps. Cheers Fred |
Quote:Outstanding. The GEMS system uses 4 O2 sesnsors - 2 upstream of the catalytic converters and 2 downstream of them. Another reason to use Megasquirt (at least not the factory EFI controller). Quote: Quote:That seals it...Regardless of the induction system I end up using, I will use some aftermarket tuneable controller. I'm going to start researching Megasquirt and SDS. Thank you all for your guidance! This has been terrific. Bill |
mgb260 Jim Nichols Sequim,WA (2631 posts) Registered: 02/29/2008 08:29PM Main British Car: 1973 MGB roadster 260 Ford V8 |
I would use a angle iron jig for drilling holes for bungs and chamfer top of holes. Tight slip fit and precut angle on bottom of bung. Then use this filler rod that anyone can do with a Mapp torch. A lot of guys use JB weld or Lab metal Epoxy. It is most important to have the fuel rail and intake holes identical. There are hold downs on the fuel rail to intake. The newer LS3/LS7 injectors are rated at 40lb and are much shorter and use the same o rings.
[www.aluminumrepair.com] Edited 1 time(s). Last edit at 01/15/2014 06:37PM by mgb260. |
Quote: I was not aware of this. Thanks. Their site says they also have brazing rods for cast iron. I 've tossed out cast iron pieces beause I don't / can't weld cast iron and it wasn't worth it to pay somebody else. Edited 1 time(s). Last edit at 01/18/2014 09:19AM by GT8MX. |
You can weld cast iron pretty easily with nickel rod. It's kinda expensive but works well.
The fluxless aluminum brazing rod will discolor and darken so your repair will show up, and it isn't as strong as a TIG repair. Jim |
That makes for a pretty sweet looking low profile intake Rick.
I'm a Volvo guy so using the white block throttle bodies makes me happy! And the WOW (weird or what) factor when you open the hood is worth it alone. Welcome back. Kinda looks like you belong here. All hail the mighty "B" cam. Fred |
I like it. Very..... different.
Gems system does not talk to a becm
Thor on the other hand is another matter :-) |
I'm afraid it does Kurt.
The ECM recieves a digital code from the BECM to enable the injectors. This happens over pin 25 at the ECM. Without this code the ECM will not power up. It can be defeated by reprogramming. But usually the cost doesn't make sense. Unless you are keeping it in the Land Rover. Cheers Fred |
in a discover series 1 there is no becm there is however a multi funtion unit that does stuff like turn signals etc I looked and pin 25 at connection C1007 is for coil #1 |
You're right Kurt,
The Disco 1 doesn't use a BECM. The early ones used the CUX14 injection without any security features. The Disco 1's that used GEMS started in 1996 and had a security code fed to them from the theft alarm unit. Its pin 26 ( I know, I said 25. didn't have my glasses on straight I guess) @ C1017 It's the same issue as the Range Rover. No coded signal, no start. |
right a P38 does have a becm
now if you look at the schem fro a disco you will notice there is a provision for {"with out anti theft } do this you will need to ground out pine #26 at c1017 this will work and has been working for the past 12 years since i first did it :-) please refer to diag A1 PAGE 9 if I follow the diag not having this ground path the starter relay will not work .. from the ETM "On manual transmission vehicles, a ground path is provided directly to the Starter Solenoid Relay’s (K137) 86 terminal. On automatic transmission vehicles, a ground path is provided to the Starter Solenoid Relay’s (K137) 86 terminal via the Park/Neutral Position Switch (X16" |
