Scott68B
Scott Costanzo
Columbus, Ohio
(562 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Radiator Parts
Posted by: Scott68B
Date: January 20, 2014 07:50PM
Doea anyone have a source for radiator parts? I'm specifically looking for a 1.5 inch copper/brass outlet. I could always cut one out of an old radiator but at this point it would be easier to order one. I've searched high and low with no luck. Radiator shops, what few are left, must be ordering from someone.
Thanks!
Scott
avbates
Tony Bates
San Jose California
(25 posts)
03/22/2008 12:16PM
74 MGB roadster 4.2 litre Rover
Re: Radiator Parts
Posted by: avbates
Date: January 20, 2014 09:34PM
Same here looking for a 90 degree aluminum 1.5" inlet
Re: Radiator Parts
Date: January 22, 2014 05:37PM
I think most shops cannibalize old radiators.
triumph10
Allan Lau
(15 posts)
12/28/2007 12:15PM
Re: Radiator Parts
Posted by: triumph10
Date: January 25, 2014 09:11AM
I purchased some aluminum 90 degree elbows from Speedway Motors. Good product at a fair price. They have a good selection of cooling parts hoses and adaptors and the such. Speedway motors.com check it out.
(4516 posts)
Re: Radiator Parts
Date: January 25, 2014 02:03PM
Aluminum:
[pitstopusa.com]
tr8todd
Todd Kishbach
(390 posts)
12/04/2009 07:42AM
Re: Radiator Parts
Posted by: tr8todd
Date: January 30, 2014 12:20PM
Copper or brass ones are soldered in with 50/50 solder. It melts at the ridiculously low temp of 400 degrees give or take. Just hit it with a torch and it falls out. I pull them out of the old TR8 rads and install them in the new aluminum cheapo ones I get from Summit with JB Weld and they hold just fine. If your going to put them in a new copper tank, you will need the torch to solder them up anyway. Make sure they are clean and well fluxed before you solder. If you don't have a torch, you literally can stick them in an oven and heat them up enough for all of the solder to melt.
