Goto Page: Previous123456Next
Current Page: 2 of 6
(2463 posts)
Re: Ford 9 inch components in an MGB axle?
Date: March 13, 2014 06:23PM
Hey, Perry got his 31 spline axles in! Check the V8 forum link above.
(6469 posts)
Date: March 13, 2014 06:38PM
I'd say the 300-350 range is going to be a little iffy myself but it's a judgement call. If the helix angle matches the 7.5 it is just possible those and the carrier could be used in the MGB housing, eliminating the machine work and making the swap to new gears, a cheaper posi, and stronger axles a distinct advantage. It's worth looking into.
perrymgbv8
Perry Stephenson
(188 posts)
12/06/2007 02:50PM
Posted by: perrymgbv8
Date: March 14, 2014 06:12PM
Hi Folks!
There seems to be a little confusion on this thread but its mostly on the right lines.
I'll try to be brief: But anyone that knows me already knows that this wont be brief :)
The crown wheel is 7.5" O/D. This is the same for the V8 diff and the 1800cc diff. Both crown wheels have 43 teeth. But the angle of the teeth on the V8 version is steeper to accomodate the angle on the bigger V8 pinion which has 14 teeth as opposed to 11 teeth on the 1800cc pinion.
My first thought was to fit 31 spline side gears into the original diff cage. As I use a welded diff this was going to be done by cutting some metal off the sides to make two flats so the gear would slide into the cage. This was not a bad idea, but the messing around involved in boring out the side bores of the cage were going to mean making some tools for the lathe. While I was playing with a spare axle in the garage I remebered that a friend had given me a 9" spool last year as something to play with. That was easy to fit. The axle tubes are more than big enough to take the thicker shafts. My man at the shop has reduced the raised section of the spool so the MGB crown wheel / ring gear will fit. In order to get the mesh right he is skimming 5mm off the face of the spool. And grinding 3mm off the mating face of the crown wheel. He said the spool was very hard material. And the crown wheel is harder, hence the surface grinding required.
The Shaft bearings for the Ford 9" shafts are a stock item where I work so they are free. The bearing size is what Moser call "Big Ford" ? The O/D of the ford bearings is 1mm bigger that the stock MGB shaft bearings. So my friend at the machine shop has made up a mount so the bearings can go on his paralell grinder / tube grinder to trim them down.
The bearings on the 9" spool are smaller in O/D than the MGB bearings. The bore on the MGB diff bearings is just a few thou smaller than the Ford. So I cleaned up the ends of the spool after cutting off the Ford bearings and heated the MGB bearings in the oven to 220C. They dropped on easily with just a light tap from a hammer with a block of wood.
I dropped the spool in and only needed to trim 25thou off one of the side shims (which were 132thou) to make it sit nice and snug.
The shafts I have are multi drilled. I'm going to use the 5x4.5" holes.
I need to trim the O/D of the wheel flanges down to fit into the recess on the brake drums so I can get them fitted flush.
The shafts are 30" with 8" of splines cut into them so I can trim them to length as required.
I'm going to re drill the brake drums to 5x4.5" and then find some 5 stud steel rims that I can get banded to the backspace and width I want to fit the slicks.
This weekend I'm going to clean up the casing and weld the tubes onto the diff housing.
The brake assemblies will be re fitted as the wheel flanges will sit in just like the originals.
So its just wheels I need to look for now.
Regarding the MGB axle and its strength!!
This is the original MGB V8 axle from 1975. It had 90,000 miles on it when I bought the car back in 1999 and used it as a show car.
The car has been drag raced since 2004 when it was a 3500 with stock tranny and nitrous. In 2006 I fitted the TH350 gearbox and a 4.6 engine with nitrous. We ran like this for 5 years until I started snapping the stock shafts. I then had the MGB shafts copied by Moser and they were very strong. However, they were machined down to 1" at the drive end to fit the stock diff. They lasted really well I think. Up to the point before I fitted the blower I was running the engine with a 600DP carb and a 250 shot of gas which made 390hp on the dyno with 602 ft/lbs of torque. To be honest, the stock MGB shafts would have held this on the dyno as the power build is quite gentle to stop the slicks overheating. But they would have broken on the launch in the strip.
So I now had the 4/71 fitted and the Moser copy shafts. And I kept adding boost and nitrous until I got down to 10.1's on the drag strip. No problems with the shafts or the diff. But con rods were now an issue.
So I scrapped the 4.6 and found a 3.9 to work with. I wont go into too much detail about the engine. But suiffice to say it has a lot more grunt than the old 4.6 did.
When we took the new engine for shakedowns it ran 9.8's on the strip. Then I did a few tweaks and got it on the rollers. With 12psi and a 175 shot she made 525hp with 545 ft/lbs on the dyno with AFR rich and timing knocked back around 10 degree's from where I think it will end up. This again was with a gentle power build on the dyno. The Moser copies were holding up fine with months of 9.6's on the strip while I was testing and data logging.
The car was so predictable that almost anyone could jump in and run a 9.6 second pass with ease.
The car was put away last November and was then hauled out for some use on 19th Jan this year. First pass was a 9.6 as usual. Then I decided to add 2.5 degree's of timing and try again. This time the engine came to life and broke a shaft and twisted the other within 2 feet of leaving the line. So the Moser copies had now been tested to their limit.
After some talks with folk in the USA it seems that the difference in thickness between my old Mosers and the Ford 31 spline (at the drive end) would yield around 89% more strength on paper.
So the obvious thought was to buy a Ford 9" axle and have it shortened to suit my car and have all the brackets welded on etc so it would drop in. And I would want a gear set as close to 3:1 as I could get. This would run out to at least $5000.00 over here.
But $250 for shafts with $290 for shipping I have what I need to work with for a lot less than a full axle.
Which is why I'm doing what I'm doing now. :)
I'm under no illusions regarding the diff. I know that improving the shafts will now just go backwards through the drive train to find the next weak link. That may be the diff gears, the prop shaft or the gearbox which has now been dragged for 8 years ??
If I add on the $400 that I will pay my friend at the machine shop for doing all the work I'm still under $1000 for the whole job.
Track info to date is:
60 foot = 1.37 seconds
The rest you can see here:
[www.youtube.com]
And the first test run this year with the new exhaust sytem fitted:
[www.youtube.com]
And what happened when i added 2.5 degee's of timing :)
If you look closely you will see that the new Hoosiers dead hooked and the front left wheel was off the ground immediately. As you can see I backed off the pedal within a few feet. I coasted over the 60 foot beam in 1.40 seconds :) I normally only run high 1.3's with full power in the 60 foot. So hopefully the new shafts will help me go sub 9.5 this year ?
[www.youtube.com]
Edited 2 time(s). Last edit at 03/14/2014 06:28PM by perrymgbv8.
(2463 posts)
Date: March 14, 2014 06:23PM
Hey Perry, Thanks for keeping us posted! I just signed on the V8 board and I find you over here!
perrymgbv8
Perry Stephenson
(188 posts)
12/06/2007 02:50PM
Date: March 14, 2014 07:13PM
No problem Jim
I've been quite busy and not had much time to come on here to update :)
Perry
perrymgbv8
Perry Stephenson
(188 posts)
12/06/2007 02:50PM
Date: March 15, 2014 05:37PM
Small update from today!
I welded the axle tubes onto the diff casing and straightened out the bent leaf spring mounts. Tomorrow I will weld in some fillets to make the spring mounts stronger as they seem to be suffering from the leverage effect from the slapper bars on the launch ? Hell ! I may even clean and paint the axle case :)
perrymgbv8
Perry Stephenson
(188 posts)
12/06/2007 02:50PM
Date: March 16, 2014 04:24PM
The axle case is now ready for sand blasting and powder coating :)
The time and effort involved for me to clean the 40 year old casing good enough for me to paint it and get a nice finish just gives me a headache. My friend will do all the work for around $50 all in !!
http://i205.photobucket.com/albums/bb270/mgbv8_photo/DSCN3937_zpsc2ff491e.jpg
http://i205.photobucket.com/albums/bb270/mgbv8_photo/DSCN3938_zps5c35e4ac.jpg
(2463 posts)
Date: March 16, 2014 04:58PM
Perry, Welding the tubes to the housing is always a good idea. The small rosette welds holding the tubes in place aren't strong enough for high HP where you get traction. Thanks again for keeping us posted.
perrymgbv8
Perry Stephenson
(188 posts)
12/06/2007 02:50PM
Date: March 21, 2014 06:26PM
I'm now looking into trimming the wheel flanges down to fit the recess in the MGB drums. But as the stud holes in the flanges are 15mm that only leaves about 2mm of metal around the edge if I use the 5 x 4.5" holes.
The MGB studs are obviously smaller, but I havent measured yet !
I'm not too concerned about the lack of metal outside the holes, but I'm wondering if the studs when pressed in will mis shape the thin outer wall and stop the brake drum dropping on?
If this does happen I can weld the studs onto the flange and then turn any extra metal off the outer edge of the flange. I would like to keep my original MGB rear brakes if I can without compromising the strength of the wheel flanges. OR! I could see if I can find some brake drums with 5 x 4.5" bolt pattern that are 10" x 2" which is what I think the MGB brakes are ? Time for some research methinks ?? :)
(2463 posts)
Date: March 21, 2014 09:26PM
Perry, Ford Ranger pickups over here have 9" and 10" brake drums with 5x4.5 lug pattern.
perrymgbv8
Perry Stephenson
(188 posts)
12/06/2007 02:50PM
Date: March 24, 2014 05:30PM
Thanks Jim!!
Thats good info mate :)
My friend has an old Ranger in his yard ready to break ?
Perry
perrymgbv8
Perry Stephenson
(188 posts)
12/06/2007 02:50PM
Date: March 27, 2014 06:16PM
Dag nabbit!! He sold the Ranger :(
I'm going to find some cheap wheels to get me by for the near future now. Because I have a dream of seeing Cragars on the MGB now :)
I've loved the look of these wheels since I was a kid. And as my 60th Birthday is only 5 years away I feel I owe it to myself to have Cragars on the car in 2015 or sooner ;)
8-9" Cragars on the rear with Hoosier slicks and maybe skinny Cragars on the front or some centreline front runners with 4" tyres would look so cool I think .. That would make one hell of a track picture at launch with wheels in the air ??
So now I have a plan for the final look of the wheels. but first I need to get some rims so I can go racing when the axle is finished.
(6469 posts)
Date: March 28, 2014 09:52AM
Perry, you might want to reconsider those Cragars. They rust, and there's not much you can do to stop it. Matter of fact, despite their popularity (or maybe the cause of it) they really are some pretty cheap wheels. I put a set of brand new ones on my MG way back when and within a year they were going bad. By the time I could replace them they had turned brown and flaky. The joint between the rim and center looked none too solid too.
Now for a really GOOD drag wheel you might look at the polished Centerline Classics. Forged, around 11 lbs each (light as you can get) and strong. Keep 'em shined up and they'll look good forever. Only flaw is the silicon center seal but that can be removed and re-sealed if it starts to leak.
(4512 posts)
Date: March 28, 2014 04:41PM
Cragars have an aluminum center. That's the part that the chrome flakes off of first. Been known to break.
Personally, I like Weld Superlite II or Pro Stars for a good looking drag wheel.
[ba5ff4f7910368ced8d0-fdac4e44cc35e2759af294e7b095ba3d.r33.cf1.rackcdn.com]
perrymgbv8
Perry Stephenson
(188 posts)
12/06/2007 02:50PM
Date: March 28, 2014 05:27PM
Thanks Jim and Carl.....
Possible disaster averted eh??
Now I have more possible wheels to look at :)
I'm out for a days bracket racing tomorrow with a normal car. But when I get back I'll do some pics of the axle case in powder coat and the next alteration that is required to the 31 spline shafts ??
Regards
Pel
Edited 1 time(s). Last edit at 03/28/2014 05:29PM by perrymgbv8.
(6469 posts)
Date: March 28, 2014 08:03PM
Welds are heavier.
(2463 posts)
Date: March 29, 2014 11:43AM
Perry, Check out these wheels: [www.team3wheels.com]
perrymgbv8
Perry Stephenson
(188 posts)
12/06/2007 02:50PM
Date: March 30, 2014 05:09PM
Thanks Jim!
I like the look of some of those :)
Yesterdays bracket racing was a real blast. I did this last year in the tow truck because the MGB does not hot lap. But the truck is in the garge broken so I used the hire car instead. A compact Skoda automatic :)
46 entrants, 3 rounds of qualifying and eliminations. I got knocked out in the 1st final. Won the 2nd final and got knocked out in the 3rd semifinal. I came 3rd overall which was cool. Overall winner was my friends wife inher Jag XK8 auto. And this was only her secnond time on track. She did a RWYB 3 weeks ago and liked it. And although the car is slow she is a demon on the lights and the car is consistent.
Right!
Back to the axle....
Only just in from Mothers days visits so I have not had any the in the garage this weekend. But I did trial fit one shaft by measuring the distance from the mating face of the wheel flange to the rear face of the shaft bearing so I had a measurment to work with. The spool is not fitted so the shaft is not sitting perfectly level.
I slid the brake plate and bearing cap on and got it to sit in place. I slid the shaft in to the required distance (+/- 1-2mm) as it was by eye. And it all looks good so far.
The wheel flange is trimmed on the O/D by 6mm and the recess in the brake drum will be opened out by around 4-5mm so it will sit on flush. I'm using the 5 bolt holes nearest the flange centre. This has left as much meat on the flange as possible while allowing clearance for the brakes and the metal taken out of the brak drum recess still leaves a raised face to locate over the wheel flange so it all lines up on centre.
Next job will be to pull a complete brake assembly off the car as I'm using spare backplates for the mock up. Then I can see if there will be any interference issues with the brakes themselves. So far it looks like this may not be a problem. Then I need to find some studs to fit into the wheel flanges to see if the back of the studs foul anything behind. I cant see this being an issue either.
In order to fit the bearings in the right position I will have to remove about 7mm of the raised section between the back of the wheel flanges where it meets the section of the shaft that is machined down to fit the bearings. Then the bearing shoyuld push on to a defined face and stop there in the right position. This has cheered me up somewhat as I was expecting to have to press the bearings on to a specific marked point and get it spot on.
Now I have another question about C clip eliminators ??
I'm assuming that the bearings will need around 3+ tons of pressure to press into place. These will be clamped into the housing with the existing brearing plate which has an oil seal fitted which pretty much mounts snug onto the thicker portion of the shaft just behined the wheel flange. The car only turns corners at low speed when in the pits. Do I need to worry about a C clip eliminator that would be pressed onto the shaft? I'm using the correct bearings to match the shafts so I assume they will not be a loose fit? I dont think I will have enough room to fit a C clip eliminator kit. So for safety's sake should I add some chemical metal to bond the bearings onto the shafts or should I add some small tack welds on the diff side of the bearings to fix them to the shafts? I can do this by cleaning the coating off the bearing hubs and pressing the bearings into place. Then add some tacks with the big Mig at work while coating the bearings in heat sink Gel and wet rags to prevent any damage to the inner oil seal on the bearings? This is all prototype stuff this time round so I'm not bothered about trying new things :)
From what I can see the C clip eliminator is just another clamp that is pressed onto the shaft like the bearing? Does this clamp need more pressure to press onto the shaft than the bearings? If it does not need more pressure to press it on then 3 good tack welds will suffice I think??
Sorry for the long ramble guys... I'm just thinking out loud at this time.
Here is a shaft and back plate mounted very close to where it should be..
Regards
Perry
http://i205.photobucket.com/albums/bb270/mgbv8_photo/DSCN3993_zps7e3f1576.jpg
http://i205.photobucket.com/albums/bb270/mgbv8_photo/DSCN3988_zps2fa012f2.jpg
Edited 1 time(s). Last edit at 03/30/2014 05:10PM by perrymgbv8.
(2463 posts)
Date: March 30, 2014 05:15PM
Perry, C clip eliminator doesn't apply to the 9" or MGB pressed on bearings. It is for the 7.5/8.8 to eliminate the C clips on those axles. For the dragstrip on those axles are OK, but leak if doing corners. Best to convert those axles to 9" press on bearing axle retention. No welding necessary, .003 interference press fit and 4 bolt flange keep the axle in. What outside axle bearing did you find that is MGB OD and large 9" ID(.003 smaller than shaft).The spacing of axle flange has to be right for whatever brakes you are using. Might want to copy MGB stock flange to backing plate.
Edited 3 time(s). Last edit at 03/30/2014 05:40PM by mgb260.
perrymgbv8
Perry Stephenson
(188 posts)
12/06/2007 02:50PM
Date: March 31, 2014 03:41PM
Thanks Jim
The bearings I have are the ones specified for the shafts which are SKF 6307-2RS-3C.
These are a stock item at work so they are free to me. This bearing is 1mm larger in O/D than the MGB stock bearings and 1mm thinner. My mate is going to grind the 1mm off the O/D and make a pair of 1mm shims this week. To get the mating face of the wheel flange in the right place he will remove 9mm of the raised shaft section just behind the wheel flange to extend the section where the bearing will press on.
Thats good that the press fit will do the job :)
The existing seal in the MGB bearing retainer plate fits quite well over the thicker section of the shaft as well. I may get some new ones or even take the shaft and retainer to a local bearing and seals place to see if they have anything that will fit a little better.
I've just ordered 10 wheel studs from a local supplier. The holes in the wheel flange are 0.590" which he says is a stock item at the race shop :)
So things are moving on nice and steady now!! I have to work all next weekend but I'm hoping to have the machine work done middle of next week so I can start assembly and maybe have it together over the Easter holidays. Fingers crossed :)
Regards
Perry
