Wotland
Wotland Wotland
(105 posts)
01/07/2008 08:14AM
Buick 300 heads porting and valve guide
Posted by: Wotland
Date: August 21, 2008 05:16AM
Hello,
I removed valve guides from my pair of aluminium Buick 300 heads to port them.
Inlet port before :
http://i54.servimg.com/u/f54/11/14/83/96/genuin12.jpg
Inlet port after :
http://i54.servimg.com/u/f54/11/14/83/96/buick_14.jpg
Exhaust port before :
http://i44.servimg.com/u/f44/11/14/83/96/buick_20.jpg
Exhaust port after :
http://i44.servimg.com/u/f44/11/14/83/96/buick_17.jpg
I am looking for Bronze valve guide. There is an compagny who sells them ? Any recommandation ?
Thank.
Dimitri
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Re: Buick 300 heads porting and valve guide
Posted by: hoffbug
Date: August 21, 2008 06:33AM
(6590 posts)
Date: August 21, 2008 08:19AM
There is one thing you may have an issue with. The bore of the guides may not be concentric with the OD because of the production process where the seat pocket and the guide were machined at the same time but not indexed on the guide OD. Better check that right away as corrections may need to be made.
Dale Spooner (Motion Machine in Danville, VA) has the bronze inserts.
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Posted by: NixVegaGT
Date: August 21, 2008 09:09AM
That was a problem on mine. I also needed to have custom sleeves pressed in through the guides for the thinner 7mm stems I got.
Did you break through to the bolt hole on the exhaust port? Does that matter? I mean do you have to have that welded shut or just plug it with the bolt and be done with it?
(4637 posts)
Date: August 21, 2008 06:11PM
For more on this... Rover Valve Guide Options
Wotland
Wotland Wotland
(105 posts)
01/07/2008 08:14AM
Posted by: Wotland
Date: August 22, 2008 10:32AM
Thank for your help.
During porting we have gone into the thread for exhaust manifold bolt. The problem is the thread in head is very deep. If you look an standard port you can see an little extension in casting for the deep thread.
But it is not an problem as we will use exhaust manifold studs. An small aluminium insert has been done to obstruct inside the thread the small hole at the end of the thread.
I found Bronze Valve Guide For Rover V8 - Machined For Seal (EA $7.50)
[www.aptfast.com]
NixVegaGT
Nicolas Wiederhold
Minneapolis, MN
(659 posts)
10/16/2007 05:30AM
Date: August 23, 2008 11:09PM
Smart! Post some pix when you get them together.
Edited 1 time(s). Last edit at 08/23/2008 11:09PM by NixVegaGT.
