hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
64-67 Buick 300 exhaut manifolds. On an Olds 215?
Posted by: hoffbug
Date: May 11, 2014 08:59PM
Does anyone know if the 64-67 Buick 300 exhaust manifolds will work on an Olds 215? Is there any weird angles, plug intefearance, or other issues?
(2465 posts)
Re: 64-67 Buick 300 exhaut manifolds. On an Olds 215?
Date: May 11, 2014 09:00PM
They will bolt up to the motor but you may have firewall clearance issues.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: May 11, 2014 09:16PM
OK. This would be going tinto a Vega.
Date: May 12, 2014 10:56AM
IME, They always dump/fit better. Less prone to cracking, flow better = win/win. roverman.
(4516 posts)
Date: May 12, 2014 12:17PM
Buick 300 exhaust manifolds on Olds 215 heads? I have a set of Buick 215 exhaust manifolds you can have if they will help.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: May 12, 2014 12:26PM
Thanks Carl... I have a set of 300 manifolds but they are in storage right now...Just wont be able to get to them for a while.
Were the 64 300 manifolds different than the 65-67 manifolds? I know the heads are different.
After years of collecting parts and dust Ive finally come to the point I need to do something with the Vega?Astre project and all the parts Ive collected, or just sell it all....
The stroker engine would have to be put on hold... I have a bone stock Olds 215 I could rebuild and get all the running gear sorted out and this thing ruuning and road worthy... Then I could always install the stroker down the road .
(2465 posts)
Date: May 12, 2014 01:04PM
Tony, This old Phil Baker article shows the 300 exhaust manifolds compared to 215. Phil said they dump better for the Vega. Lots of other info in the article.
[www.teambuick.com]
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: May 13, 2014 02:21PM
I have the article. I had spoken with Phil a few times in the past...Just a really nice guy.
I just wasnt sure of the Olds heads in Particular... They are layed out a little different than the Buick heads.
joe_padavano
Joseph Padavano
Northern Virginia
(157 posts)
02/15/2010 03:49PM
Posted by: joe_padavano
Date: May 16, 2014 11:19AM
"I just wasnt sure of the Olds heads in Particular... They are layed out a little different than the Buick heads."
The intake and exhaust flanges on the Olds and Buick heads are exactly the same.
Date: May 16, 2014 05:24PM
Exhaust port and bolt layout are the same for all 215s, but spark plug location and angle vary between Olds and Buick. I don't know if spark plug clearance might effect fitment of 300 heads on an Olds 215.
Date: May 18, 2014 08:22AM
The flange location between the Olds and Buick 215 is slightly different but the same headers will fit. Just makes a slight difference in body clearance.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: May 18, 2014 03:46PM
What about spark plug access?
Date: May 18, 2014 06:34PM
You may have to cut away the straps between the ports on the header flanges.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: May 18, 2014 07:30PM
But the stock cast iron 64 -67 manifold don't present any plug access issues on Olds heads?
