Re: cam saver groove option in hydraulic lifers
Tony, got a pic ? EDM hole, for mechanical, works. What's the sales pitch ? roverman.
[www.crower.com]
CAMSAVER HYDRAULIC LIFTERS The maximum in cam lobe and lifter life. If high spring pressures or extreme and unusual operating conditions have you worried about lobe scuff and lifter wear, insist on Crower “high-lube” CamSaver lifters. These lifters deliver 20% to 30% more oil to your lobe and lifter faces for the best possible insurance against premature lobe and lifter failure. Specially machined flats put 12 to 16 ounces of additional oil per minute at each lobe without adversely affecting engine oil pressure (nominal drop of just 1 or 2 pounds). Crower CamSaver lifters incorporate the same precision ground radius face and finish as our standard lifters to insure quick break-in and trouble free operation. Stole the picture from the web... |
The EDMs were only available for solids. this is thier solution for hydraulics I guess... They say it only lowers oil pressure 2-3LBs and after mulling it over I figured it couldnt hurt. I wont be high winding this engine so I wont worry about a little additional windage raining down on the rotating mass.
More importantly, who among us checks the actual lifter to bore clearances ? Perhaps more important than a small flat, on the lifter ? I suspect excessive bleed-off, on the primary feed lifter bank, to be problematic. roverman.
Good point on the lifter bores!
They state only a 2-3 lb pressure loss...Have a high volume pump and adjustable pressure regulator. I guess if that cant keep up the lifters are going back. |
