MT/ Indy X-ram IR intake for 215/RV8, what next ?
Date: August 07, 2014 11:31AM
Rare,big n' nasty ! Ports are 340 Buick size, with 50mm round/unported inlets. I refuse to "live" with (4) DCOE webbers, so maybe slide-plate/Hilborn injection ? This manifold desires ported TA heads, in a racing environment. What inches ? Seems like 5L. might be wise, considering a possible vintage/something class. Suggestions ? Thanks, roverman.
quietone
Larry Mimbs
Tennille, Ga.
(93 posts)
07/13/2013 04:22PM
Re: MT/ Indy X-ram IR intake for 215/RV8, what next ?
Posted by: quietone
Date: August 07, 2014 08:21PM
Be aware, most Hilborns have no idle circuits.
Date: August 08, 2014 11:16AM
Thanks, One trick is mount a small return fuel tank, "near" the engine. What I need now, is a semi-retired pattern maker,to school me or build ,"core boxes", for this manifold. It is, match plate tooling. Individual cores, for each runner, might be an option. I "shan't" re-finance my home, to make this happen ! Anybody ? Cheers, roverman.
Date: August 08, 2014 05:25PM
this thread needs photos
(and you need EFI, even if it takes a lot of trickery to pull off a retro look)
quietone
Larry Mimbs
Tennille, Ga.
(93 posts)
07/13/2013 04:22PM
Posted by: quietone
Date: August 09, 2014 08:26AM
Hillborn must have return to tank. Mixture strength is controlled by "pill" (orifice) in return line. " If it ain't smoking black smoke at idle, it ain't gonna run." Pretty much single purpose system. Drag race.
Date: August 09, 2014 07:47PM
This guy's Hillborn is well sorted for roadracing, but I know it took a lot of work to get it that way: Girvin's Allard.
http://www.britishracecar.com/BobGirvin-Allard-GT/BobGirvin-Allard-GT-BC.jpg
Now imagine a finned aluminum cover set real low between the two rows of throttle bodies with fuel rails, injectors, and injector wiring all hidden away underneath. Perhaps you could sneak in some IAC plumbing too, to achieve a civilized idle.
Date: August 11, 2014 11:24AM
8" runner length, cross ram. I suspect a "small" advantage to wet stack, mech/Hz injecting. I envision cast aluminum air plenum, each bank, over thrumpets/nozzels ? To be continued, likey as a race motor. Thanks, roverman.
Date: August 13, 2014 05:28PM
I forgot! It's near twin, is on cover of HOT ROD Mag, May 1970,(behind the suit). Looks like it's on a 215 based motor. Currently this cover is posted on "V8Buick" site. My MT manifold is one pc. Cheers, roverman.
Re: MT/ Indy X-ram IR intake for 215/RV8, update.
Date: August 15, 2014 02:21PM
Ports at head juncture, average .97" x 1.99", un-ported. I'm not sure if this equates to 64' ,300 or ? Onward, roverman.
Dan Jones
Dan Jones
St. Louis, Missouri
(280 posts)
07/21/2008 03:32PM
Posted by: Dan Jones
Date: August 15, 2014 04:26PM
1964 Buick 300 intake port measures 1.75" tall but 1" wide unported. Dan
Date: August 18, 2014 02:00PM
Perhaps now is a good time, to state our ported port inlet sizes ? Say 300/340 ? I suspect this "Indy", has .240" added at the top. I heard 66', 340 is larger than 65' ? Onward, roverman.
Re: MT/ Indy X-ram IR intake for 215/RV8, Need vintage pic's please .
Date: August 22, 2014 04:15PM
Hi clan, Can anyone help me find Mickey's use of this manifold at Indy ? Vintage is likely 62'-64' ? I'm going to complete the tooling and casting, of this cool and effective, piece of racing history. It will be sized at the head juncture to fit unported TA heads,(close to ported rovers), and will easily open to ported TA and 64'/300 ports. Electronic injector nubs, for each runner, will be located underneath the manifold,(runner are "straight shot" into the head). Cheers, roverman.
Date: August 22, 2014 09:18PM
1962,in the one car Dan Gurney drove that year. I don't know if maybe someone may have tried to qualify that car in 63 but the Buick v8 didn't make the race again.
Date: August 27, 2014 11:17AM
Seems logical, I would machine mountings for aftermarket, Hz fuel rails. Anyone have a "300", intake manifold width ? Onward, roverman.
