lars49 Larry Barnes Colorado Springs (177 posts) Registered: 06/11/2009 02:12PM Main British Car: 1980 MGB GM LA1 3400 V6 |
GM PCM mounting bracket
I've been wondering just how to mount my GM PCM since it doesn't have any attachment points. I found that the bracket from the following trucks fits perfectly. I has a couple of mounting feet and the PCM just clips in.
Blazer 2WD 1995 - 2005 Blazer 4WD 1995 - 2005 S10 pickup 4WD 1995 - 2004 S10 pickup 2WD 1994 - 2003 Blazer trailblazer 2WD 1999 - 2001 Blazer trailblazer 4WD 1999 - 2001 The GM p/n is 15995679. I got mine from ebay. |
Scott68B Scott Costanzo Columbus, Ohio (561 posts) Registered: 10/25/2007 11:30AM Main British Car: 1968 MGB GM 5.3 LS4 V8 |
Re: GM PCM mounting bracket
Hi Larry,
I'm using the exact same bracket. Got it with my PCM which came from a 2001 S-10. I like it because it's easy to get the PCM in/out should you need to. Scott |
Scott
Now you have me curious. How did you get the S-10 PCM to work with the 3100 engine? Aren't they different? Larry |
Larry,
I'm going to run my LS4 with it. It's been reflashed with V8 code. It's the "0411" PCM. The 3100 is long gone. Scott |
