lars49
Larry Barnes
Colorado Springs
(177 posts)
06/11/2009 02:12PM
1980 MGB GM LA1 3400 V6
GM PCM harness shell disassembly
Posted by: lars49
Date: October 15, 2014 08:28PM
Does anyon know how to get the back of the PCM harness connector shell off? The harness is for the 340 engine. There are 2 locking tabs on each enn the need to be pressed together, but there is something that is holding it together in the middle. Is there a release tab I am missing?
Scott68B
Scott Costanzo
Columbus, Ohio
(562 posts)
10/25/2007 11:30AM
1968 MGB GM 5.3 LS4 V8
Re: GM PCM harness shell disassembly
Posted by: Scott68B
Date: October 16, 2014 09:09PM
Larry,
Do you have a picture? Sounds similar to the 0411 plugs. The covers were a real pain to remove in one piece. I'm not putting them back on until I'm sure I'm done.
lars49
Larry Barnes
Colorado Springs
(177 posts)
06/11/2009 02:12PM
Posted by: lars49
Date: October 17, 2014 11:54AM
Scott,
Yes, indeed a real PIA! I finally got them off. I had to partially cut one before I found out how to get them off. There are two slots in the middle that you have to insert a thin screwdriver and then lever to disengage two locking tabs in the middle of the cover. Picture to follow once I get some batteries for my camera.
