Maximizing the Compression Ratio
Re: Maximizing the Compression Ratio
That is a good read. I used several of the detonation prevention methods in my engine and I think that is why I'm getting away with running 8 lbs boost with 11:1 compression.
Jim, I'm curious, what is air inlet temp,(after blower), at 8 psi.boost ?
Don't know, I don't have a way to measure it. I do have water/methanol injection right after the blower that will cool it down considerably but I don't have any data.
lars49 Larry Barnes Colorado Springs (177 posts) Registered: 06/11/2009 02:12PM Main British Car: 1980 MGB GM LA1 3400 V6 |
You could try this [www.racegas.com] just type in your zip
Better to tune for readily available octane so you can buy gas anywhere. Closest to me on that site is 25 miles away through horrible traffic and they aren't open on the weekend.
Has anyone ever used Calico's CT2 coating.
If so do you have any feed back such as how did you apply it, how did you prep the surface, how well has it worked? |
