rockea Rocke Amonette Norman, OK (1 posts) Registered: 09/03/2009 11:44PM Main British Car: 1980 MGB Rover 3.5 |
Buick 215 3/4 speed bellhousing
I am using a GM style pressed steel clutch lever and it does not work particularly well with the stock clutch pivot stud. The stock pivot ball is 7/16", 20 thread and overall length is 1.4" with .5" threaded.
3.5 from a TR8, Rover Pressure Plate with T5 from a Camaro. I would like to go to an adjustable Pivot Stud but any suggestions would be appreciated. Thank you Rocke |
Re: Buick 215 3/4 speed bellhousing
Rocke, Summit carries an adjustable pivot stud.
[www.summitracing.com] Edited 1 time(s). Last edit at 03/14/2015 05:15PM by mgb260. |
