5 Speed Tranny
I have an Olds 215 and Im going to be installing it into a 1977 MGB,I want to also run a 5 speed trans. (T5) I was looking for some advice on on what bellhousing and clutch parts to use that will all match and bolt up to the 215...and also what axle to use and gear ratio would be best.... want to get the right combo the first time.. :)
Re: 5 Speed Tranny
Re: 5 Speed Tranny
"and also what axle to use and gear ratio would be best.... want to get the right combo the first time.. "
Your stock axle has a gear ratio of 3.909:1. For all-around use in my Buick 215-powered MGB, I prefer 3.27:1 gears. Depending on transmission gear ratios, camshaft choice, personal taste, and even tire size, a different gear ratio might suit you much better. If I were doing more autocrosses and track days, I might have preferred a ratio around ~3.4:1. Maybe. IMHO there's something to be said for doing your engine swap first, getting your car running well, enjoying it for awhile, and then coming back later to swap axles. You'll better appreciate how you're going to enjoy your car, and thus which axle ratio will suit you better. (That's a better outcome than doing an axle swap, and then deciding you chose the wrong gear ratio.) Downside: you'll have to make two trips to a local driveshaft shop... but that's not too expensive. I chose a Ford 8.8 axle. It hasn't really given me any problems, but I regret the choice because IMHO it's way too heavy. A lighter axle would give better ride. I plan to swap to a Ford 8" and at the same time upgrade to rear disc brakes and coilovers. Should be a big weight reduction. |
