mgbman
Marshall de Leon
Salem, Oregon
(54 posts)
01/15/2014 11:43PM
Mark 2 Jaguar Chevrolet 350
Buick 215_T5
Posted by: mgbman
Date: May 25, 2015 02:18PM
With the preponderance of T-5 boxes out there now, anyone have a good suggestion on which one to use behind the Buick 215?
I want something that is "almost" a bolt up and where I don't have to spend a lot of time/money playing around with adaptations.
I now that it depends on shifter location, but apart from that????
(2463 posts)
Re: Buick 215_T5
Date: May 26, 2015 12:20PM
Most people like the Camaro V8 T5, bolts right up to the 215 Muncie 4 speed bellhousing. D&D have an adapter for 3 speed belhousing to Ford T5.
(4514 posts)
Re: Buick 215_T5
Date: May 26, 2015 02:14PM
Like Jim said, GM 4 & 5 speed tranny bolt patterns have been the same since the late 50s. I used a a dual bolt pattern factory Buick 215 3 & 4 speed bellhousing. My '91 Camaro V8 T-5 bolted right to it with zero issues. Aftermarket Buick/Old 215 bellhousings will do the same. If staying with the stock rear end, a T-5 with a .63 overdrive makes driving on the Interstate much better. Use a GM V8 T-5.
mgbman
Marshall de Leon
Salem, Oregon
(54 posts)
01/15/2014 11:43PM
Re: Buick 215_T5
Posted by: mgbman
Date: May 26, 2015 08:36PM
Much appreciated......I did have a handle on a Camaro T5 but checking the tag number, turned out to be a V6 model.
40indianss
don foote
(83 posts)
08/01/2013 04:35PM
Re: Buick 215_T5
Posted by: 40indianss
Date: May 27, 2015 12:42AM
the used ford t5 is generally less expensive, more readily available, and has the same ratios as the elusive gm v8 with d&d bellhousing plus adapter from gm to ford pattern the trans mount pad locates on the crossmember plus it sits parallel with simple hole drilling into the crossmember to bolt the trans mount pad and the adapter allows the longer ford input shaft to fit into the pilot bushing properly another is the shifter is vertical not at an angle and comes up in the center of the mgb opening but if you are diehard gm go for it
Re: Buick 215_T5
Date: May 27, 2015 01:12AM
Don, I recently heard that maybe that adapter plate can cause an interference issue with the firewall, have you seen any evidence of this?
(4514 posts)
Re: Buick 215_T5
Date: May 27, 2015 10:18AM
I have. Jim Watson has the adapter with a Ford T-5. It required some extra relieving at the firewall/tunnel area. Glad that I stayed all GM.
(2463 posts)
Re: Buick 215_T5
Date: May 27, 2015 06:33PM
The Mustang V8T5 has a lower first at 3.35. OD is .68. V6 has a .72 OD. Aftermarket and Ford Racing T5 has 2.95 first and .63 OD, same as Camaro T5.
40indianss
don foote
(83 posts)
08/01/2013 04:35PM
Re: Buick 215_T5
Date: May 28, 2015 02:14AM
i have found no interference issue with the adapter plate if I remember correctly it is dimensionally similar to the gm style surface on the bellhousing that a t10 or t5 would bolt to with it being slightly vertically longer to use the ford trans bolt pattern if I recall the chev/gm is shorter/wider pattern while the ford is slightly taller/narrower of course the mounting bolts from adapter to bellhousing surface are countersunk so there is no interference also with the d&d bellhousing I ordered no clutch fork opening is present there is no I did have an issue with the top of the trans casting hitting the trans tunnel between the rear of the heater box footwall vents and vertical sheetmetal that normally holds heater/fresh air/fan controls and/or radio about 3/4"high x 5"wide x6"long bread pan gave plenty of clearance maybe I was lucky in sourcing my used mustang t5 with the 2.95 first gear I still think they are easier to find than the somewhat similar gm t5 just an opinion
(2463 posts)
Re: Buick 215_T5
Date: May 28, 2015 05:43PM
You were lucky, I forgot about the 83-84 NWC Mustang T5. It did have the 2.95 first. Those are about as rare as the Camaro V8 one. I like the newer Mustang V6 T5 with the .72 OD. With the new 3.31 rear gears. I think Carl is right with the 2.95 first and switching to .73OD with 3.4-3.7 rear gears.
Re: Buick 215_T5
Date: June 20, 2015 02:18PM
Near the top of the page, look for a line that starts "Go To:" and click on the words "New Topic".
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1165 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Re: Buick 215_T5
Posted by: ex-tyke
Date: June 20, 2015 02:19PM
Quote:
PS how do you start a new topic or thread?
Click on "New Topic" above the first post
N7614Y
Terry Looft
Wilmington, Ohio
(9 posts)
02/15/2014 12:39PM
1976 MGB GT V8 GD2D1 2809 G Stock
Re: deleted
Posted by: N7614Y
Date: June 21, 2015 09:40AM
Thanks, looked everywhere but there.
