Emergency brake set up for S10 Drum Brake rear
I am planning my winter projects and one of them is to get my 3.73 posi S10 rear in the MGB V8. I have decided to stay with drums and seem to recall someone out there made a a kit to hook up the emergency brake with this set up.
Anyone Know? |
Merv Merv Hagen IL (104 posts) Registered: 05/21/2008 05:48PM Main British Car: 1980 MGB Buick 215 T-5 Trans |
Re: Emergency brake set up for S10 Drum Brake rear
Keith, D&D used to carry emergency brake kit for S10 rear axle. I do not see it on their web page but you should give them a call.
[www.aluminumv8.com] |
Keith, I used a Lokar E-Brake kit to attach to Ford 8.8. Cable attachment should be similar for the Ford or Chevy. It comes with the outer and inner components. Good Luck.
Kelly, is this what you are talking about: [www.speedwaymotors.com]
yes Keith, that is similar. My kit came from Summitt, but sure they are same. the hole in the MGB lever had to be enlarged for the larger bolt , but no problem
