Costello Buick 215 block
Hi, I'm in Scotland! I have a freshly found genuine 1971 MGB GT Costello that requires full rebuild. From new it was fitted with a V8 engine, number begins with "JM" which I believe is a 1963 Buick 215 block. It requires a full rebuild. Costello fitted Buick blocks along with Rover ancilliaries / heads etc. Can anyone help me by telling me what obvious differences were between the Buick 215 and Rover blocks and heads etc. please. Cheers Paul
Re: Costello Buick 215 block
Pretty much interchangeable. You can substitute any Rover engine complete. The 3.5L was essentially identical. Rover made some changes later with the displacement increases so watch things like main journal sizes and combustion chamber volumes.
Early Rovers were essentially the same, except for the pressed in liners. Later, they improved the heads, strengthened the block, added four bolt mains, bored it, then stroked it...
People say that Rover improved the Buick engine, yet the Buick/ Olds/Pontiac 215 has never, ever had a slipped liner since it is cast in place. [en.wikipedia.org] [www.v8forum.co.uk] [www.gomog.com] [www.roversd1.nl] [www.britishv8.org] Edited 3 time(s). Last edit at 12/03/2015 10:17PM by MGBV8. |
For background on the car you should visit [www.mgcostello.com]
If it is a geniune Costello conversion you should have a Costello build number plate on the car somewhere ? This could be a very rare car indeed as Ken made less than 200 of these GT's. Send some pictures of the front suspension setup as I have some experience of working on early Costello's Perry |
This is a pretty cool old article too: [www.britishv8.org]
Just one of many interesting Buick and Rover V8 articles in the BritishV8 archive! |
Neither Buick nor Olds nor Rover painted their aluminum engines! One of the distinguishing features of the Buick/Olds blocks compared to Rover is a smoother/shinier exterior because they used permanent molds for the outside whereas Rover blocks have a sand-cast finish both inside and out. Another very easy way to distinguish them is that the Buick engine has parallel ridges cast in around the bell housing flange, almost like cooling fins that never matured.
Thanks. That's helpful. Any other info appreciated!
If you want to restore the finish on the block you can have it blasted with soft media such as walnut hulls. Are you rebuilding the engine? The Olds and Buick engines had cast in liners which are easily distinguished from the Rover slip in liners.
Pics of the engine in question, including the right, front pad of the block with the the stamped numbers would greatly aid identification.
