b6281t Robert Stolt White Bear Lake,MN (16 posts) Registered: 03/01/2015 10:39AM Main British Car: 77 MGB 2008 GM 3800 with T5 |
Prelube Engine Oiler
I made a low cost engine pre luber from a water fire Extinguisher I found on Craigs List.
I used a 3/8" Flare fitting that I chucked in a cordless drill and fed into a belt sander to remove the flare. then used a 9/16" od copper washer to seal my modified fitting to the Extinguisher. I made up a hose from the Extinguisher to the oil pump cover on my series 3 3800 V6 ( I replaced the oil pressure sending unit with a hose fitting ) I poured a gallon of oil into the tank pressurized it to 60 psi and let it rip. |
Jim Stabe Jim Stabe San Diego, Ca (830 posts) Registered: 02/28/2009 10:01AM Main British Car: 1966 MGB Roadster 350 LT1 Chevy |
Re: Prelube Engine Oiler
I did pretty much the same thing as you did using a compressed oxygen bottle and some plumbing fittings. I ran the oil through a filter before it enters the engine. I like your solution better - much easier and cleaner. I had to use a pressure pre-lube because the LT1 engine doesn't have a distributor driving the oil pump.
