b6281t
Robert Stolt
Glenwood City, WI
(16 posts)
03/01/2015 10:39AM
77 MGB 2008 GM 3800 with T5
Prelube Engine Oiler
Posted by: b6281t
Date: February 27, 2016 11:43PM
I made a low cost engine pre luber from a water fire Extinguisher I found on Craigs List.
I used a 3/8" Flare fitting that I chucked in a cordless drill and fed into a belt sander to remove the flare. then used a 9/16" od copper washer to seal my modified fitting to the Extinguisher.
I made up a hose from the Extinguisher to the oil pump cover on my series 3 3800 V6 ( I replaced the oil pressure sending unit with a hose fitting )
I poured a gallon of oil into the tank pressurized it to 60 psi and let it rip.
Jim Stabe
Jim Stabe
San Diego, Ca
(719 posts)
02/28/2009 10:01AM
Re: Prelube Engine Oiler
Posted by: Jim Stabe
Date: February 28, 2016 02:31AM
I did pretty much the same thing as you did using a compressed oxygen bottle and some plumbing fittings. I ran the oil through a filter before it enters the engine. I like your solution better - much easier and cleaner. I had to use a pressure pre-lube because the LT1 engine doesn't have a distributor driving the oil pump.
