tr8todd
Todd Kishbach
(351 posts)
12/04/2009 07:42AM
Another T5 trans question
Posted by: tr8todd
Date: March 13, 2016 07:56PM
I just pulled the mock up Olds 215 block out of the go-cart/race car thing I picked up last weekend. I was told the tranny was a T5, but when I searched the numbers on the tag, it came back T50. Brand new, but a T50 non the less. The GM bell housing that was in the car has two sets of holes. The T50 used the ones spaced farther out in a big rectangle. The other four holes are more of a square pattern. Educate me on the ways of GM here. All of my experience is with Rover engines, bell housings, and transmissions. What fits these holes? Please tell me this bell housing isn't a unicorn.
(3639 posts)
79 MGB, Buick 215
Re: Another T5 trans question
Date: March 13, 2016 08:51PM
The T-50 uses the same pattern as the T-5, T-10, Super T-10, Muncie, etc.
(3639 posts)
79 MGB, Buick 215
Date: March 13, 2016 09:04PM
You called it a race car. Some say that the T-50 has a race car shift pattern, so you are in luck. It's a pretty good tranny & would be fine in that project. The bell housing is the same as mine, a Buick/Olds bell with the dual bolt pattern. The holes not being used in yours is for the 3 speed.
Here is an article by Jim Blackwood about the T-50.
[www.britishv8.org]
tr8todd
Todd Kishbach
(351 posts)
12/04/2009 07:42AM
Posted by: tr8todd
Date: March 13, 2016 09:40PM
Thanks guys. I call it a race car because I don't know what else to call it. Wife was joking that I should call it number 12, because that's how many cars I'm up to. If I do anything with this, it will most likely get the Rover 4.0 I already have rebuilt and bagged in the garage, an Edelbrock 4 barrel, and a Rover 5 speed. Altho, seeing how it has a TR4a rear diff, and I just so happen to have a TR3/4 4 speed sitting here, I keep thinking it should have a TR3/4 engine with twin DCOE Webers hanging off the side.
(5761 posts)
Date: March 14, 2016 11:26AM
Depending on the gears it is fitted with, the T-50 could be a good choice, especially being new. There were three versions, and it would be possible you could have the extremely rare version with a 1:1 5th gear and no overdrive.
Considering the guys who built this were engineers (I think you said) it seems likely that a good match of weight, engine size, transmission ratios and rear axle might be likely. You might want to consider finishing it up as intended.
The strength of the T-50 and the TR4/6 axle are pretty comparable. Neither are going to stand up well to 300+ hp but both should do fine at 200. If the vehicle weight can be kept below 2000 lbs that can be enough.
joe_padavano
Joseph Padavano
Northern Virginia
(121 posts)
02/15/2010 03:49PM
Posted by: joe_padavano
Date: March 15, 2016 11:00AM
The T50 was used in the mid-1970s behind such powerhouse motors as the Buford 231 and the Olds 260. It may be the only five speed that's weaker than the T5.
(3639 posts)
79 MGB, Buick 215
Date: March 15, 2016 01:43PM
That is pretty pessimistic, Joe.
Sure, it's not rated for nearly the torque of a T-5 (some of them aren't rated for much torque, either), but it's a great little tranny for the lower power/lighter weight projects. Kurt Schley ran one for years in his Olds 215 MGB. The shift pattern might take a bit of getting used, except for those used to 3 on the tree (or floor).
Oh, you left out the Chevy Monza V8. Engine options included the 305 & 350 (although detuned).
joe_padavano
Joseph Padavano
Northern Virginia
(121 posts)
02/15/2010 03:49PM
Date: March 18, 2016 01:35PM
"That is pretty pessimistic, Joe. "
I'll note you didn't say it was wrong, however...
