Richl705 Richard Lilly Fairfax, Virginia (42 posts) Registered: 12/03/2007 10:48PM Main British Car: 1958 MGA Buick 215 V8 |
Which radiator for the MGA?
Still working my way through this MGA build. I have been looking at options for radiators and have seen a few of them used with a 215ci, although mostly custons builds. Finding a radiator with the right dimensions for the space in the front of the MGA but still holding enough for a 215 is a challenge. Question would be if I find a radiator with the right dimensions but it was previously on a 3.0L engine, is that close enough? I believe the original Buick 215V8 radiator held 12 quarts. Do I need to come up with a radiator that holds that much or is the efficiency of the newer radiators enough that I can go with a smaller volume? Given I will use a pusher fan does that allow for a smaller radiator? Another question is, can you turn a radiator on its side given the MGA profile allows for a taller than wider radiator? Thanks
Re: Which radiator for the MGA?
There are a lot of variables for how big of a radiator you need... Since the V8 will leave little room for the heated air to escape the engine bay, you'll want the biggest radiator you can fit. I'm not familiar with the A's frame, but assuming you don't want to modify it, measure how much room you have between the rails to determine max radiator width & figure out how tall it can be & then search Jeggs, Summit, etc. to see what's out there. Also, puller fans are generally considered more efficient than pushers so you might want to consider that. Also, you can mount the radiator at a angle (e.g. lower part further forward than the upper part) which can help you fit a bigger one in many cases.
My experience has shown that modern engines don't seem to need as much radiator per displacment as their older versions. My 2.8 V6 cools quite well with a MGB radiator designed for the 1.8.
I don't have any magic formula, just go by the seat of the pants so to speak, but I'm sure enough that a TR4 radiator will cool my 4.0 six in the MGA that I'm building around that. It does fit the chassis pretty well, dropping down between the front frame extension sides nicely. I think it would be ok with a small V8 as well with a good electric fan. If I'm wrong I'll have a lot of rebuilding to do but I'm taking the chance based on previous experience. |
jblanchard@hcpg.net Jeb Blanchard Collierville, TN (53 posts) Registered: 12/07/2007 01:01PM Main British Car: 1961 MGA Chevy 4.3 Vortec V-6 |
Thanks for all the great input.
Jeb, I have been looking at the pics of your car for a long time and really like the work. The suicide doors are really special. Richard |
