Goto Page: 123Next
Current Page: 1 of 3
(6587 posts)
BOPR oil filter bases
Date: June 23, 2016 04:24PM
I'd suggest this thread could be made a "sticky".
I'll start this, anyone who has more info please add to it. The purpose of this thread is to show and identify all existing oil filter bases that can be used for the Rover V8, Buick 215, 300, V6 and other Buick V8 engines. I've got photos of three so I'll go first.
The first photo is of the "Metric" filter base as mounted on the Buick 340 in my '71 MGB. Note that the frame rails have been modified to accommodate a 32" wide crossflow radiater. Curtis has used one in his car by denting, and later notching his frame rail.
The second photo is the stock 215 base. With a forward enough engine position it is possible to fit the filter between the steering rack and swaybar with this mount, in which case a hood scoop or bulge is almost certainly required. The third photo shows me holding the 215 base up next to the Metric base on the engine.
(6587 posts)
Re: BOPR oil filter bases
Date: June 23, 2016 04:26PM
The 4th photo shows a big block filter base. These are interchangeable with the small block parts. This one almost certainly came off a late 60's 400. In the 5th photo you can see that it positions the filter forward and down, likely interfering with the swaybar but there may be applications that could use it.
(4628 posts)
Date: June 23, 2016 05:15PM
Here's a couple of pics from the Photo Gallery.
Metric Base (again)
http://www.britishv8.org/MG/CurtisJacobson/CurtisJacobson-I.jpg
My D & D Swivel filter.
http://www.britishv8.org/MG/CarlFloyd/CarlFloyd-D.jpg
(4637 posts)
Date: June 24, 2016 02:57AM
Metric base, as installed on my 71 MGB GT.
After just a little hammer work, there was plenty of clearance for a PF47 filter to spin-on/off.
Later, I decided to fit a Scirocco style radiator.
I cut/patched the frame, just forward of the oil filter, to keep the radiator under hood height.
(6587 posts)
Date: June 24, 2016 08:14AM
Looking at that last photo, it might be worth trying one of the big block filter bases.
ex-tyke
Graham Creswick
Chatham, Ontario, Canada
(1166 posts)
10/25/2007 11:17AM
1976 MGB Ford 302
Posted by: ex-tyke
Date: June 24, 2016 08:45AM
This is the setup that was on my Olds 215 engine - metric base with a D&D supplied swivel adapter.
tdecell
Trey Decell
MS
(31 posts)
04/10/2010 12:13AM
1974.5 MGB GT 3.9L Rover
Posted by: tdecell
Date: June 25, 2016 08:05AM
Here's where my filter hits with the metric base. Trying to decide whether to go with the D&D swivel or notch the frame...
Blown v8
Bryan Phipps
(72 posts)
03/10/2013 04:52PM
Posted by: Blown v8
Date: August 07, 2016 01:07PM
Would this Ford "swivel" filter adaptor fit ?
(2633 posts)
Date: August 07, 2016 02:21PM
It may work with the right threads on bolt to motor or motor to bolt. You would use the Ford filter recommended for that adapter.
Edited 1 time(s). Last edit at 08/07/2016 02:24PM by mgb260.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: August 07, 2016 02:58PM
It looks like the GM GN swivel adapter is discontinued.. Part #966639. Is there another source available?
This looks quite a bit different than the one posted by Graham.. I wonder where you can source those?
Edited 1 time(s). Last edit at 08/07/2016 04:38PM by hoffbug.
(2633 posts)
Date: August 07, 2016 03:30PM
It was found on 4.1 Cadillac V6 also, probably junkyard only.
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: August 07, 2016 04:32PM
Would this be the correct part number to make a remote mount?
[shop.perma-cool.com]
(2633 posts)
Date: August 07, 2016 06:49PM
Tony, Your pic is of the "Metric" V6 cover. On Adapting the Ford swivel adapter you would also have to look at the O ring location. Ford has 3/4"-16 thread, V6 "Metric" 18mm-1.5, 215,300,340 Buick V8 is 13/16"-16.
Blown v8
Bryan Phipps
(72 posts)
03/10/2013 04:52PM
Posted by: Blown v8
Date: August 13, 2016 04:36AM
Later Rover front covers,(later then 76 known in the uk as SDi ) are in fact 3/4" unf,
I'll let the pics do the talking
If you have a later front,then the Ford part is a straight fit,
(2633 posts)
Date: August 13, 2016 04:27PM
Bryan, Very nice addition to this thread!
hoffbug
Tony Hoffer
Minnesota
(323 posts)
10/15/2007 05:25PM
Olds 215 EFI
Posted by: hoffbug
Date: August 17, 2016 09:30PM
Bryan.. Would that also work on a later Buick V-6 cover and pump?
Blown v8
Bryan Phipps
(72 posts)
03/10/2013 04:52PM
Posted by: Blown v8
Date: August 18, 2016 11:56AM
I'm sorry,but I don't know the thread on the v6 cover !
If you could check it,and it's 3/4 unf,I couldn't see a problem,
Looking at the centre bolt of the pump,someone good with a lathe could make one with what ever thread you'd need.
(2633 posts)
Date: August 18, 2016 05:49PM
Buick 3.8 "Metric" has 18mm-1.5 thread.
Greg55_99
Greg Williams
(102 posts)
11/01/2007 07:12PM
Posted by: Greg55_99
Date: August 31, 2016 11:04AM
You're missing one filter base. Leyland P76 on the far left:
http://www.roversd1.nl/sd1web/tuning/v8motoren/013.jpg
http://www.roversd1.nl/sd1web/tuning/v8motoren/014.jpg
Points filter forward at an angle but brings it down farther.
Greg
jjohanski
James Johanski
(61 posts)
11/15/2017 08:57AM
Posted by: jjohanski
Date: November 11, 2019 06:20AM
I am resurecting this post. What is not answered is this. Does the Range Rover Oil pump base that Bryan Philips posted fit an earlier Rover or Buick front cover? It appears that it might. The pictures posted show that the Ford 90 adapter fits the oil pump base from those Rover V8s. Pictures also show the oil pump base installed on a Rover engine. Is the engine pictured installed in an MGB? Will the 90 adapter from Ford clear the pulleys and front sway bar? These questions went unanswered and unchallenged. Anyone know?
Goto Page: 123Next
