Re: Rover V8 Build, $5000 Budget
Thanks for that picture Carl, I was searching to find a visual side by side comparison. I wonder how many cars that size is the difference between a go and no-go? I don't have a lot of experience with small engine bays, my last two projects were a '49 Ford F6 that went to Canada and a '67 Ford Falcon Futura that went to Australia before that. The gentleman with the engine said he would let me know by Saturday what he decides and the price.
My all-time fav Buick 300 powered MGB. I have driven it many times. It is so sweet!
[www.britishv8.org] |
M favorite too. Can't wait to see Chris' though.
Quote: Probably the nicest MGB V8 on the road. |
I have a Rover 4.0 engine, Buick 300 heads, crank, and 90% of the parts needed to build a D&D Stroker motor.
Would love to sell this package for a very reasonable price. i've had it sitting around for a long time and realize I will never build it. |
I thought I would give an update on some things. Martyn gave me a wonderful offer on his setup, but getting it across the border proved cost prohibitive. If anyone in Ontario is looking for a great start on a stroked Rover they should contact him. I contacted a auto yard in AU regarding a P76 crank; they said it would be $100 plus shipping. Shipping was $300. Greg has one with a flywheel for sale for $400 so that is probably the best deal your going to get if you are stuck on a P76 crank. The gentleman with the '64 Buick got back to me and said he would take $600 for the engine and aluminum 4 barrel intake-- a great deal as far as I'm concerned but he got cold feet and I didn't push him. In the mean time I have procured a complete '98 4.0 (craigslist, $75) and a set of stripped '64 300 heads (ebay, $150 after shipping).
I am still tossing ideas around on which direction I want to head eventually. The 4.0 would make a great high rev engine in its stock form (6.111 length rods works out to a 2.182 rod ratio), but as I am most interested in low to mid range torque it is not very appealing. The combo that is looking good right now is a 4.6 crank (I might be able to get if for free semi-locally if I trade some parts off the 4.0) and use the 4.0 rods with forged Icon 305 pistons (1.133 comp height) and the rod ratio works out to 1.892. Still spectacular. I would be .102 below deck and the compression ratio would be 9.8:1 but could easily be increased to whatever I want by milling the heads. 283 cubic inches would probably suit me just fine. Doing this would allow me to use a lot of the parts I already have (covers, rods, etc) which would be nice. I haven't torn the engine apart yet but the seller said it ran when pulled, albeit a bit roughly. I am tempted to forgo the tophat liners and just pin the block. If they slipped in the future all I would be out is a set of rings, gaskets and my time (assuming I didn't allow the problem to go undetected for a long amount of time). With all this said I would plan on dropping the budget closer to $3000. I think its definitely doable whether I choose to go carbuerated or Megasquirt EFI. At any rate, it looks like the $5000 Rover V8 isn't a thing anymore. Edit: I forgot to mention I would need to bore the wrist pin holes in the pistons .0179. Edit: The 1.133 comp height Icons have a -10cc dish which I mistook to be a +10cc dome (Summit states all values as +x cc's even if its referring to the dish volume). The better option would be the 1.265 flat top Icons. They have a negative volume of 3.2ccs (valve reliefs) and would come .030 above deck for a compression ratio of 10.8:1 with the stock 300 chambers. Edited 2 time(s). Last edit at 01/22/2017 08:04PM by Casey. |
FWIW, I just got back my 4.6 short block. Picked up the whole 2003 LR it was in for $250 and got most of that back on scrap value, so buy in was just the time I spent. Block had 2 out of round cylinders and needed to be bored. So did the 4.0 block I dropped off at the same time. Could not find oversized pistons for a 4.0 so that block is wrapped up and stashed in the garage. Found +.020 4.6L pistons in England with rings delivered to me for $350. Machine shop services and a new camshaft came in at around $1800. Estimate to do the heads with porting, Chevy 305/350 springs, cut the spring pockets for the new springs, and install new larger Vitesse valves was $1400. All in I should be right around $4K for a basic rebuild with a cam and head work just for the long block. Still need flywheel, tranny, clutch, bell housing, headers, intake, oil pan, and a bunch of other stuff. Luckily I have most of those parts. Further confirms my premise that if you are starting from scratch, just go get a LS variant. The LS3 package thats in my other current project was a $9800 buy in for everything. It was in a wrecked 2010 Camaro SS with 11,000 miles. Lost track of the parts I have sold off to recoup my initial outlay, but in the end, the LS swap is going to be about the same price as the 4.6 swap, and make close to twice the HP with an indestructible 6 speed transmission.
