mgaman
marshall de leon
(78 posts)
09/17/2008 06:11PM
Mark 2 Jaguar 350 Chev. V8
Buick 300 intake
Posted by: mgaman
Date: December 14, 2016 10:44AM
I know that this is the wrong forum but hopefully Curtis will redirect......
I have a mix of Buick 215 and Buick 300 intake manifolds--- does anyone know a way to identify between the two?
It seems simple (perhaps) but I am having trouble getting it done.
(5449 posts)
Re: Buick 300 intake
Date: December 14, 2016 11:23AM
The width. The narrower ones would be 215 and the wider ones would be 300.
(3310 posts)
79 MGB, Buick 215
Date: December 14, 2016 11:50AM
Or post the part numbers here.
Also, the 300 intake covers/seals the lifter valley. The 215 does not.
Edited 1 time(s). Last edit at 12/14/2016 11:53AM by MGBV8.
mgaman
marshall de leon
(78 posts)
09/17/2008 06:11PM
Posted by: mgaman
Date: December 14, 2016 12:18PM
Thanks guys---
Much appreciated...
(1858 posts)
Date: December 14, 2016 12:46PM
Also, the 300 has a squared off bottom that seals the valley where the 215/Rover has a separate valley cover.
mgaman
marshall de leon
(78 posts)
09/17/2008 06:11PM
Posted by: mgaman
Date: December 14, 2016 09:10PM
OK, it appears that there is no Buick 300 manifold amongst this lot.
Is there a good after market intake manifold that would suit a Carter 4bbl carb on a Buick 215 with 300 heads?
(3310 posts)
79 MGB, Buick 215
Date: December 14, 2016 09:59PM
If you have hood clearance issues, use the OEM Buick 215 manifold. Otherwise, the Edelbrock 2198 is a smidge taller. If clearance is not a consideration, the Huffaker single plane has ports that match the 300 heads better. Hard to come by & expensive. There is also a Wilpower single plane, but has Buick/Rover sized ports.
(1858 posts)
Date: December 14, 2016 10:07PM
One more intake is Offenhauser. Actually 2, The Dual Port which I had on a Jeep and 360 Equa Flow single plane. I think you can buy the single plane new but it is about $ 100 more than the Edelbrock. The dual port is more for lower RPM.
(2885 posts)
Date: January 06, 2017 05:29PM
Actually, the Offy 4bbl and 2x2bbl. manifolds, are a smidge+ lower than the oem 4bbl. They are easy to port 64', 300 Buick size ports. They also work as a good base, to weld on a "Dyers Blowers", 6V71 mounting base,(even more work). art.
