tr8
Paul MacDonald
Canada
(12 posts)
10/25/2008 04:07PM
TR8 Coupe Rover 4.0
Don Coleman A/C bracket
Posted by: tr8
Date: June 02, 2017 11:31AM
I would really like to find the bracket that Don Coleman used to mount a Sanden compressor to his Rover motor.
[www.britishv8.org]
Thanks
Paul
(3364 posts)
79 MGB, Buick 215
Re: Don Coleman A/C bracket
Date: June 02, 2017 11:52AM
That car was built by Fast Cars, Inc. So, Ted Lathrop, Steve Carrick, or Terry Senneker may remember where they got it. Possibly from a street rod parts supplier.
(4366 posts)
Date: June 02, 2017 01:59PM
I expect Ted or Terry fabricated it.
tr8
Paul MacDonald
Canada
(12 posts)
10/25/2008 04:07PM
TR8 Coupe Rover 4.0
Posted by: tr8
Date: June 02, 2017 02:14PM
There is a logo on it and now that you mention it, it looks like a Fast Cars Inc logo. I just sent them an email, will post result. Thanks
Paul
Edited 1 time(s). Last edit at 06/02/2017 02:18PM by tr8.
(2466 posts)
Date: June 02, 2017 05:39PM
It appears to be a pretty simple part. If you don't have luck with FastCars, use some plywood to define the shape & mock it up to determine thickness of steel needed - or thickness of steel + spacers if/as appropriate. Then use the plywood mock-up to mark & cut it out on steel. File/sand/generally clean up the edges & take it to a chrome shop. Or if you're not up to cutting it out, simply take the plywood mock-up to someplace local who can cut it out for you.
(3364 posts)
79 MGB, Buick 215
Date: June 03, 2017 12:03PM
Easy enough to start with a universal bracket & bend that shape, cut to the correct length, & redrill the hole (or 2).
http://www.autopartsdb.net/assets/images/ProductImg/T/T9079.JPG
(5519 posts)
Date: June 04, 2017 11:02AM
I've found that cardboard, followed by aluminum sheet metal is a very convenient way to make bracket templates.
tr8
Paul MacDonald
Canada
(12 posts)
10/25/2008 04:07PM
TR8 Coupe Rover 4.0
Posted by: tr8
Date: June 12, 2017 12:04PM
Just got an answer from Fast Cars, they custom made it for Don's car.
